Hoover washing machine - door won't open and drum won't spin, error displayed is e08, ideas anyone? Thanks :-)
  • Anonymous Mar 12, 2014
    Error code E08 displayed
  • Anonymous Mar 30, 2014
    washing machine is on but not working
  • 1,768 Answers
1. please provide the model number for the washer
2. this is a timer error code and it seems that it locked the door during the spin cycle.
There may be a malfunction sensor or you will need to unplug the washer to reset the washer to complete the cycle.
Something electronic has caused the washer to shut down to protect the electronic circuit. You may have a defective timer.
Posted on Mar 13, 2010
Testimonial: "Thanks for your help, it's working fine now :-) "
6ya staff
SOURCE:
Why is the drum not spinning on my Hoover VisionTech VTS712D21 Washing Machine?
It could be the drum bearings are seizing or something is causing it to jam.
If this is the case the motor would work too hard and draw too much current and consequently would cut out for a time and then reset.
Removing the drivebelt and turning the drum by hand would show if this is probable.
Feb 20, 2017 | Hoover Washing Machines
Hover OPD 714 D 7kg . What does E08 mean
http://service.hoover.co.uk/manuals/OPH714D_1.pdf
user manual
http://www.whitegoodshelp.co.uk/hoover-error-8/
here is a description of the common error your machine has
and how too solve it
hope it helps you...
Mar 04, 2015 | Washing Machines
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Hoover WMH168D error code E08
I posted this elsewhere by mistake, I have a Hoover Optima which had an E08 fault, the forums suggested a Tachometer issue. I fixed the fault it was just the motor brushes. i made a video including testing the tacho and changing the brushes that cost me a tenner. easy fix hi I had this fault google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on you tube http://www.youtube.com/watch?v=xYn-f78GB4U if its any use.
Oct 17, 2012 | Hoover Washing Machines
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
Washing Machines Logo
955 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
