See the picture below. it can be hard to see at first glance, but it is there...youll need a small paperclip to reset it
bill
i have tom tom 910 . where is the reset button? - efba6e2.jpgdata-src="/uploads/images/efba6e2.jpg" alt="efba6e2.jpg" class="h_mi" />
Next to the connector on in the recessed cavity.
SOURCE: Tom Tom 910 software
i have the same device
its china made and i have the same problem
its a bad device it has no memory to install ant program
if u have any solution please tell me
SOURCE: Tom Tom 910 Green light but does not come on.
Remove battery and disconnect from power for 5 minutes, also remove map card, this will reset the device. Try it out
click;
Repair4GPS: How to Clean, Upgrade, Repair, Mod, Disassemble a GPS ...
see here
http://www.tomtom.com/lib/doc/legal/lw/LW-English-US%20CAN.pdf
To only way you can fix it is taking apart the Tom Tom, checking if the flat ribbon cable and connector to the screen are well in place and eventually replace the display ($80 on Ebay).
Unfortunately this will invalidate the guaranty, and you risk to damage your GPS if you are not a really experienced DIYer. Tom Tom offer one year full guaranty on all their receivers.
Contact Tom Tom and get it repaired:
Support URL: http://www.tomtom.com
Support Phone Number: 978.287.9555
Support Email Address: [email protected]
Hope this may help;
DON'T FORGET TO RATE:
SOURCE: tom tom Go 910 won't turn on
Suggestion
Charge the tomtom over night,
Reset
And before you switch on connective to the PC and run the updates via you Supplied CD Software.
SOURCE: Faulty battery on my Tom Tom Go 910
Go to this site and get the pdf with pictures on how to do it. Just be careful with the hard drive cable. Delicate tabs.
http://www.unc.edu/~bmoc/tomtom/Tomtom%20Go%20910%20Dismantling%20Manual.pdf
