My wifi on my iphone does not work at all, is there any way i can get it to work or will i have to buy a part for the phone?
Find your solution from the list,
Apple Iphone Smartphone
Codes:
Software & Hardware Problems
Find Your Solutions for other Apple Products:
Apple Iphone 3G
Apple iPod Touch Digital Media Player
Use ziphone
You should get setting for wap and add them into phone local network in setting pad also try connecting to free wi-fi spot also get setting
SOURCE: wifi on iphone 3g is not picking up wifi signal
it may be finding it but not showing the passcode screen to enter your wep key.
tap the wifi settings and set you network information and the wep network key which is located on your router.
If you put any other code in your wifi won;t connect.
SOURCE: Wifi & Bluetooth unavailable
If you have the 1.1.4 compatibility patch uninstall it. (For the iPhone).
SOURCE: can't connect Blackberry Curve 8320 to 2wire wifi
W002 - Wi-Fi Connection Failed
Means The phone cannot get an IP Address from the Server.
Common issues are
The signal is to weak to make a reliable connection
WEP is configured incorrectly or WPA
DHCP may be disabled, it needs to be enabled on the router
There are other more technical issues to this but without more information this should be a good start.
SOURCE: My Iphone wifi button is grey out
Resolution
First, sync your iPhone or iPod touch to iTunes to backup your user information, Contacts, Calendar, and other data. Then try the following steps in order.
One
On the device, tap Settings > General > Reset > Reset Network Settings. Check to see if the device now displays the Wi-Fi address or Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth). If there is a Wi-Fi address and a Bluetooh address, then you're done with these steps and you can resync your settings and your media using iTunes.
If there's still no Wi-Fi address or Bluetooth address, then continue to step two.
Two
On the device, tap Settings > General > Reset > Erase All Content and Settings. Check to see if the device now displays the Wi-Fi address and Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth). If there is a Wi-Fi address and Bluetooth address, then you're done with these steps and can resync your settings and your media using iTunes.
If there's still no Wi-Fi dddress or Bluetooth address, then continue to step three.
Three
If there is a Wi-Fi address and Bluetooth address, then you're done with these steps. If there is no Wi-Fi address or Bluetooth address, then continue to step four.
Four
If there is no Wi-Fi address or Bluetooth address listed after doing the above steps, then your iPhone or iPod touch may need to be repaired. See the iPhone Service FAQ or iPod Service FAQ for additional service information.
> Wifi does not work
i am also having the same problem. my iphoe WiFi cannot detect any wireless network. it keeps on searching and searching........but no result. i reset network setting and restored phone to factory setting but no slution. anyone can help!!!!!!!!!!!!!!!!
wifi
how to connect to wifi on the iphone
iphone 114 upgraded-wifi grey
i have too
