When i access yahoo messenger the message coming is'this computer does support the audio compression format'..what to do
Install K lite Codecs for Vista and run Autio Trainning Wizard again
I am using hp 2713tu model laptop where yahoo messenger installed. But voice chatting is not enabled due to my computer is not supporting voice compression. How i can solve this problem. If i can get a detailed roadmap, it will be more helpful.
plese send reply at [email protected]
Visit this freecodecs
site (or just simply google freecodecs),download and install the k-lite free codec pack for Vista.
Enable the bitstream options.
If you use a PCI soundcard,and video card, check the latest drivers for Vista on the manufacturer's website.
Hope it helps to you.
This is a warning message due to improper sentting of your messanger and your net-protocol. Allthough even then you can make your voice-chat without any problem. So dun wrry just ignore the message.
Thanks
iqbal
computer doesnt support audio compression
no audio ,,,,,,,,
In yahoo, my computer says it does not support the required audio compression format. Please send me an answer to this situation.
hi i have same problem pls send me soloation thanks
vista very very bad
I NEED A VIDEO FREE CODEC
whn i open yahoo msngr its coming this computer doesnot support audio compression format
when enter to conferance chat this computer does not support for audio compression format is dispalyed.please notify methe way how could i solvethis problem.
when i access yahoo messenger the message coming is'this computer does support the audio compression format'..what to do
problem in audio for windows vista problem
i have a problem in voice chat as my computer doesn't seem to support audio compression format..am using windows vista home premium
I have Vista premium (new hp laptop) and when I tried to use yahoo voice ( Pc to phone option) it says Voice is not enabled message and it is not accepting my credit card to do the payment.
Then I tried the same activity thru dial up thru differnet service provider and it was enabled , but I am not able to hear from other side. Should I Install the codec software ? I am using Vista compatible Yahoo messenger. Please send me a reply at [email protected] ....
Thanks in Adv,
I cant use voice in yahoo
when I access the yahoo and click the voice chat the message is : your computer does not support the audio compression format
I have vista home Laptop, in which when i connect with yahoo messenger 8.1.0 , it gives me error message at the statup "your computer doesn't support the required audio compression". pls help me
