its possible something in this DLP is on the lens that projects the picture onto the screen or the mirror (do not touch it) or between the lens and the inside of the screen---anything will if there show up in the picture.
In some cases I have used compressed air to dust these out but carefully.
See my previous answer and clean for something that might be between the optical lens of this DLP and the mirror or between mirror and screen--anything even something tiny will show in the picture.
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem. If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue. Lamp replacement procedure is easy and written in user manual. Thanks.
You need to explain more about you problem. The type of signal input and the method of connection to the signal source. You can to a hard reset on you television by completely unplugging you television from any type of power source. Disconnect it from all signal sources and unplug it form the source of power. Leave the television this way for about half an hour and reset up your connections and see if your problem has gone away. If this does not solve your problem try going to the www.sony.com website and go to the support section. Put in the model number of you television and look at the frequently asked questions and troubleshooting sections to look for answers to problems like yours. They may have a soulution for you. On the website you can find customer service help and they should be able to help you with the problem. I hope this helps you with your problem.
http://repairs.sunnyoasis.com/sonylcdtv/ this is a link on what to do i had same problem picture is like brand new now good luck this takes about 3 to 4 hrs
Sony wega blue dot or star pattern on screen http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655 Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620 Sony LCD Rear Projection TV - Optical Block Problems
