Cycle through caption settings until it goes off, each time you push the caption button it goes to the next caption setting then finally back to the the begining.
Menu
Setup
Audio
captions
scroll to the top captions off
If captions are turned off in the TV, and you still have captions, you will need to do the same thing to the cable box. It can also be the source of the captions, If you have a 5 year old in the house it will help them learn to read!
Go back and just "look" to see if the captions are still turned off. if it is still on CC1 or CC2, the captions are still on. If they are, you must turn captions off and then follow on screen prompts to make sure they are indeed off. (Did someone turn on the captions on your cable box or other receiver?) (If they did, this may be the reason that you can/t turn them off on the TV !)
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network: Setting Closed Captioning:
Press and release the MENU button and then select "Preferences."
If the cc button on your Sharp remote control isn't turning them off then the captions may be coming from your cable box. The hidden menu to access closed captioning on the cable box is usually found by turning it off and then (yes I did say turn the cable box off) then press the menu button on the front of it immediately after turning it off. Then you navigate down to captions and disable them. When you turn the cable box back on the captions should no longer be there.
What is the input source? Could the captions be on from a set-top box (cable/sat/dvd player)? I know with one satellite box, the only way to enable captions on the second TV (an older set) turned out to be putting the box in single mode and turning on the captions. This meant that both sets got the captions. Thus to turn off the captions for the main TV, you have to turn them off in the satellite dish menu.
Please let me know if this helps.
Cindy Wells (I'm assuming that pressing the CC button on the remote hasn't helped and this isn't a case of open captions being provided.)
manual below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Turning On Captions
Pressing the CC button displays caption options:
? CC on: Displays captions.
? CC off: Turns off captions.
? CC mute: Displays captions when the Mute
button is pressed.
To assign your preferences for captions, see “Using the
Closed Caption Menu” on page 33.
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option. 1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
5)If you're watching aDVdon your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
Are you talking computer or TV?
Closed caption on a TV is when the volume is muted and it prints the speech in a box on the screen. You have to turn it on in the menu.
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
