I have a new Topfield TRF7170 The pixilating has got so bad that at times I have delete the programme. Especially 7 which I watch all the timeI have a new Topfield TRF7170 The pixilating has got so bad that at times I have delete the programme. Especially 7 which I watch all the time
AnonymousMar 26, 2014
will not play what i have recordwill not play what i have record
You can't post conmments that contain an email address.
Re: Recording and actually WATCHING the programmes I...
This feature its not from the TV is for DVR box, that storage the information on a hard drive inside, check your DVR model and number and google the proper manual for it
I haven't met a DVR or a PVR that doesn't have twin tuners. This is the only way for digital reception to be acceptable for a lot of people used to watching one channel and recording another for the last few decades with analogue tv and the trusty VCR.
You should indeed be able to record one channel while you watch another or if the equipment is of premium quality it is possible you could record two programmes while watching something already recorded.
I hope this helps.
I could not find an owners manual for this TV but if it is like most TV's usb is for playing media, Not recording. I found a site that talks about your TV. The first reviewer explains the usb is for watching (not recording). I have a different TV and same holds true. IF you really want to record TV and have a computer with Windows 7 or Windows 8 you have capability to record to the computer and then move it to a usb to watch it elsewhere.
Try to play a couple of dvds on another dvd player thru the point yours stopa to see if the recording is bad or the player portion is defective. Also is unit under warranty?
Well no matter the DVR, you should be able to record 2 programs at once...but you CANNOT watch a 3rd live while they are recording...also, if your DVR is hooked up to more than one tv and someone is watching something else in the other room, it will not record 2 at once, either. You can watch RECORDED programming while 2 others are recording, but not live tv.
You might want to check how many "inputs" your DVR has...most have 2 which allows the double recording...if you have an older DVR maybe you only can do one at a time. On my DISH box, they call these "TV1" and "TV2".
I cannot find on online manual for this model. If dual channel recording an actual specification for the model? If it really should be able to record two channels at once then it may be similar to the DishNetwork DVR. It has one input but internally splits and creates two different outputs for two different channels.
Check to see if there is a mode setting for single/dual. You will need to set it to "dual". The Dishnetwork DVR has what it calls TV1 and TV2. You can record to TV1 but cannot watch a different channel on TV1 while it is recording. You CAN however watch and record a different channel on TV2 while TV1 is recording. (and vice versa). You can also record two shows while watching other recorded shows.
I'm guessing that you may need to look for some recording options to be able to record two channels at once.
