Battery light on dash goes on and off at least 3 times a day, lonest time on about 2 miles down the road. Alernator new (probably got took on that one by Midas), battery ok..what else could cause this? Car at Dave Arbogast now in Troy, OH. I've had drivers window replaced every 4 years, socket in turn signal done a few weeks ago, alternator last week and belt, today headlight and day lights and tires..Radio light went out a long time ago. (meant Alternator). 2nd Sunfire, never owned one past 8 years. 2002..not a GT..basic.
@p4str4woo, I also am having this same problem, and researched on where this "charging relay" may be and could not find anything in the manufactures manual that indicates where this relay may be. @arlene_royce, did you ever have any luck in coming to a solution for this issue?@p4str4woo, I also am having this same problem, and researched on where this "charging relay" may be and could not find anything in the manufactures manual that indicates where this relay may be. @arlene_royce, did you ever have any luck in coming to a solution for this issue?
You can't post conmments that contain an email address.
Most likely you have a bad connection, or relay. the diming switch relay seems to be a problem for a lot of people. I rebuilt mine, still working ok 10? years later. (20 year old car). Follow wire from headlight back to relay probably on the passenger side of engine compartment (just guessing).
You may be able to get repair manual here:
http://www.manualslib.com/
you have a draw hook a test light to ground cable them from cable to ground terminal on battery if the light is bright start pulling fuses until it dims, one thing most of the time its the radio so start with radio fuse
I have a 2004 dodge stratus 2.4 dual overhead cam. When driving down the road, bell goes off, check engine light comes on, and it's like I'm driving on limp mode, when going over 2000 rpm's, there's a severe stutter. After getting code for light it points to cam shaft sensor, which i changed. I also changed crank shaft sensor. After all of this was done, drove great for about 30 miles and the same thing happened all over again. If anyone can point me in the right direction it would be greatly appreciated.
