My Sennheiser RS126 headphones suddenly stopped working. The base doesn't seems to receive the sound from my PC: the green on/off light never comes on.
The sound card and headphone jack are working fine (verified with another pair of headphones). The base and the headphones worked fine this morning.
Any ideas?
SOURCE: Bad battery for my Sennheiser HDR 45 headphone
A replacement battery can be purchased from Sennheiser for $20.00.
Battery is: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
SOURCE: My sennheiser 120 headphones are wearing out. After much use.
You can buy the HDR 120 model which is basically the headphones lone
These will work with the base in conjunction with the set you have now.. or as a replacement
You can also buy replaceable ear cups for less than 20 dollars (check the Sennheiser website)
Finally you may want to replace the rechargeable batteries in the headphones you have
Just make sure you replace them with the exact type.. I believe those are NiMh AAA
Pop them out and go to any Battery Plus or Radio Shack.. a new set probably run you less than 7 bucks
My point.. for less than 30 dollars you can have your old headphones working and looking like new ones
Give the new batteries an overnight charge before using them
Good luck
SOURCE: replacing headphone connector
The impedance or resistance of the two different sets of wires might be different. The higher the impedance the less signal. If your cable is long enough you are better off spending the five or so dollars for a new plug. Red is right, green or blue is left and copper is ground.( Usually) Unfortunately not all manufacturers agree. Also what could have happened is a short between the wires that you soldered.Make sure they are physically separated from each other and insulated.
SOURCE: Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
