if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
Yup, my front loader has the same issue.I found the rubber seal around the door has a fold in it that holds water and sometime candy wrappers and various stuff from pockets.
By wiping the fold in the seal out on occassion and not closing the door in between uses, the issue was resolved.
I have the same problem. Nothing works fcfor the mildew. i have bleached it, used simple green and used baking soda. That washer is the biggest piece ever!! Good Luck!
not machiines fault no bleach in wash powder any more used 2keep washer clean and smell free only solution new door seal and wipe clean every time u use still some bleach in coulur powder
This happens when you keep the door shut. Run an empty load with extra chlorine bleach to kill the mold spores. Keep the door open to prevent mold or mildew from growing again.
Run a cycle with or without clothes using a 1/4 cup of beach diluted with 3/4 cup of water...max out the auto bleach dispenser with this solution. After using, leave the door open to allow the water within to evaporate. We had the same problem and this was the fix.
I Talked with a retail appliance sale's person about two weeks ago because I had the same problem. Buy a can of country time lemonaide and put three scoops into the drum and run it through a regular wash cycle. This removes the odor. Also around the rubber door seal you can pull the rubber back from the drum side and wipe around the seal with lemon juice due to water and detergent being trapped in the seal. Once every month should do the job. It works for me.
The smell problem is actually because of the softener....its nassssty stuff it coats the interior of the washer and forms a grease like residue. I would use Washer Magic (available at all appliance parts retailers) (only half the container in front loaders) and a hot wash. Also keep spraying the boot with bleach and water soluiton every few hours it will dissappear after awhile.
please rate my help
