Reebok Rt1000 Treadmill Walking Belt Logo
Posted on Mar 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
THE BELT ON OUR MACHINE IS BROKEN CAN I BUY A REPLACEMENT AND HOW DO WE FIT THE NEW ONE ON ?
  • Techmotionusa.com
    Techmotionusa.com Aug 11, 2013
    You can buy a belt from us at techmotionusa.com or you can either go to usedtreadmillrepairparts.com or treadmilldoctor.com. If you do not know the model number, you can cut the belt off, measure the length from end to end and the width and order it that way.
Techmotionusa.com
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 163 Answers
  • Posted on Jan 23, 2016
Techmotionusa.com
Expert
Level 2:
New Friend:
Cheetah:
Answers
163
Questions
0
Helped
84535
Points
319
The treadbelt can be installed by removing the front roller, the drive belt, rear roller and screws in the siderail. You do not have to remove both sides, just lift the deck and slide new belt on. To save yourself some agravation, you may cut the old belt off.
THE BELT ON OUR MACHINE IS BROKEN CAN I BUY A - belt-our-machine-broken-buy-uuxxv1o5nwvpx1g0ljlbpp00-4-0.png
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly... 877-805-1030
Sportsmith LLC
Level 3:
  • Reebok Master 920 Answers
  • Posted on Nov 23, 2015
Sportsmith LLC
Reebok Master
Level 3:
Answers
920
Questions
0
Helped
514516
Points
111994
Alma chee
Level 2:
New Friend:
  • Expert 69 Answers
  • Posted on Feb 02, 2015
Alma chee
Expert
Level 2:
New Friend:
Answers
69
Questions
0
Helped
81802
Points
161
TREADMILL BELTS
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Dec 02, 2014
TREADMILL BELTS
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
2325
Points
9
We have every make and model treadmill belt in stock and offer a $99 treadmill belt installation service - Ben Service Technician GYMWORKS HealthEquip TreadmillBelts.com.au
Anonymous
Level 2:
  • Expert 83 Answers
  • Posted on Mar 24, 2010
Anonymous
Expert
Level 2:
Answers
83
Questions
0
Helped
107869
Points
222
You can get a new belt from Treadmill Doctor. I think that Treadmill Doctor incline instructions for replacing the belt. If not you can contact me through Fitness Fix-It.
Where can I buy a replacement V Belt for my Home Comfort HCWP 1102 washing machine?
same question, same answer...
you did not supply country, or location - telepathy do not work, nobody can help if data is not known.
i would suggest any store selling belts (automotive, tire places, white goods repairers and suppliers), just grab old belt, take it with you and salesperson will be able to determine from the numbers on the belt what length and profile of the belt will be and will sell you happily replacement.
1helpful
2002 Volkswagen Passat power steering belt pulley broke off
find the bolts attaching the bracket to the engine (possibley2 or 3) Buy a genuine replacement assy and fit get a new belt as the old one may have suffered damage. Replace where you removed the broken bit and adjust the belt to the correct tension
No power to brushes no result when brush switch activated
If you hear the brush moter running then the belt driving the roller has probably broken. It can be easily replaced by removing the brush plate underneath and pulling the roller out. Replacement belts are available on-line or may be available in hardware stores.Fit the new belt over the steel motor spindle first, then place the belt over the roller and insert the roller.
The belt will break if the roller gets jammed, so buy 2 belts and keep one as a spare.
Balance has snapped off my arm, where can i get a replacement and where do i buy a new belt?
LPtubes.com or follow this link exactly..
http://www.lptunes.com/Numark-turntable-belts-s/106.htm
The 1600 belt should fit on 1610's with no problem.
Balanced snapped off? You will need to buy another replacement Tone arm at: http://www.instrumentalparts.com/allnusppa.html
Mine broke while in transport on a plane. Would suggest taking weight off when transporting or purchase a cover for the tt1610's if one wil fit on it.
Hope this helps.
1helpful
Drum won't turn
the dryer belt has broken or the motor is defective, start by checking the belt, here is how to replace the belt.
  • Look up your specific model number and buy a replacement belt from a Maytag dealer or a third-party supplier of replacement appliance parts.
  • Unplug the dryer and remove the exhaust vent tube from the back.
  • Pull out the lint screen. Use a Phillips screwdriver to remove the screws around the lint screen housing.
  • Slide the blade of a flat screwdriver underneath the top panel at one of the front corners of the machine. Pry the top panel up slowly, being careful to not nick or scratch the finish. You should hear a snap when you've lifted the panel high enough; that noise is just the latch releasing.
  • repeat Step 4 on the other front corner of the machine and then lift the hinged lid up.
  • Firmly grasp the top edge of the front panel of the dryer. Wiggle it to the front and back slightly as you lift upward, and the panel should come loose from the latches holding it in place.
  • Slide the front panel forward while your assistant supports the inner drum. Pull the front panel completely off of the machine.
  • Reach underneath the drum and pull out the broken belt.
  • Slip the replacement belt around the drum while your assistant continues to support the front of the drum. Turn the belt so the grooved side fits into the visible grooves around the circumference of the drum.
  • Get on the floor again and locate the motor underneath the drum. You will see two round pulleys; the larger one is the motor pulley and the smaller one is the idler pulley. Grab a section of the slackened belt, fold it in half and push the loop underneath the idler pulley. Wrap the loop around the motor pulley.
  • Push the idler pulley to the side, away from the motor. The grooves on the pulley should fit just right with the belt, and moving the pulley over should create tension in the belt all the way around the drum.
  • Slide the front panel back up against the machine, working with your assistant to fit the front of the drum into place. When the drum is secured to the front panel, slide the panel straight down into place. You may hear or feel it lock into place when you've pushed down far enough.
  • Lower the top panel and push it down until it snaps into place. Replace the screws surrounding the lint screen housing and put the lint screen back.
  • Reattach the exhaust vent tube and the electrical plug.
  • 0helpful
    2answers
    Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
    take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
    if it sucks your hand onto the tube , the machine is working as a vacuum machine
    then check fro a blockage in the elbow section near the head
    if there is no vacuum , junk it and get a new one
    1helpful
    2answers
    Beater bar belt needs replacedon a dyson DC14 animal
    Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
    Its in the instruction book
    3answers
    Replacing belt on bread machine
    Where did you get the replacement belt ? My brother is looking for a belt for a similar model K6761 which uses the same belt (I think). It is about 24" around and 1/4" wide. It has (3) grooves inside and the backside has many notches. The motor has grooves, it would go on there. Where did you get the replacement belt ? thanks [email protected]
    Top Reebok Exercise & Fitness Experts
    ZJ Limited
    ZJ Limited
    Paul Carew
    Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
