Aiwa HV-MX1 VHS VCR Logo
Posted on Mar 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I use this machine to play an NTSC cable input on a PAL tv.
S. Gontko
Level 2:
New Friend:
  • Expert 142 Answers
  • Posted on Mar 16, 2010
S. Gontko
Expert
Level 2:
New Friend:
Answers
142
Questions
0
Helped
56871
Points
310
Typically you wil need to set the ouput to pal to match the tv but it will do what you want.
Sony kvj21mf1ak
It sounds like either the TV or the device is trying to do S video instead of composite video.
see if you can change the output type of the media player and make sure that the TV input is not set to S Video.
Nov 19, 2013 • Cell Phones
Will the dvp 311ok play ntsc dvd i am in australia and i am reg 4
As long as the NTSC DVDs are not region coded, and your TV is multi-standard (able to receive NTSC as well as PAL signals via A/V inputs or similar connections), the player should play NTSC just fine through it
I assume this is a PHILIPS player? If so, most PHILIPS DVD players support NTSC playback on PAL TV.
You are correct, Australia is region 4 for DVD standard. The only restriction would be region codes.
2answers
I want to play an NTSC tape on a PAL television
This is a VCR alone machine?Not a DVD and VCR combo?VCR alone machine dosen't have auto NTSC/PAL setting to play all the world regions.
Could I change NTSC to PAL N my LCD Sansung LN T
NTSC and Pal are mainly related to Cable/Air reception. Unless you are trying to connect a SCART cable, you can probably just use the video inputs of the TV. Power Supply differences will be the big issue probably.
3answers
Change from PAL to NTSC
To begin, the first and second problems are completely unrelated.
If you bought a PAL TV and are playing an NTSC source, the result will be an invalid format. The two sources are not compatible. However, there are converters available, see: http://www.converters.tv/signals/ntsc_to_pal.html (just as an example).
To the second user. My first guess is that you need to select the proper input on your TV. Look for the "input" button on your TV remote and toggle through each input until you see a picture. The problem may be more complicated than that, but, to troubleshoot, I need to know: what TV you have, how many devices and what devices are hooked to the TV.
4answers
When convert PAL-NTSC w/ SV-5000W to Samsung Plasma only B & W pic
Switch through the TV input selector until you find the proper input channel , probably you are using the wrong input.
Please help
Have you try: NTSC on PAL TV On • NTSC discs will play correctly on PAL-only TVs.
Off Use if your TV is already NTSC-compatible.
Many recent PAL TVs are compatible with NTSC input and so this setting can be switched off. Check the operating
instructions that came with your TV. See also About NTSC on PAL TV on page 124 for related information.
Nextech N600 DVD player problem
You may have connected one of the component outputs (usually colored red, green, and blue) of your DVD player to the composite input of your TV. Connect yellow to yellow. See section 3.2 for hookup details. Also, if you've hooked up component video, check the three cables to make sure one of them hasn't become disconnected or developed a short and that they are connected in the correct order. If you use an s-video connection, the chroma wire maybe broken -- try a different cable or try the composite connection.
If you live in a PAL country (most countries outside of the U.S., Canada, and Japan) you may be playing an NTSC disc in a PAL player, but your PAL TV can't handle the signal. If your player has a switch or on-screen setting to select the output format for NTSC discs, choosing PAL (60 Hz) should solve the problem. See section 1.19 for more information.
2answers
Certain dvds only play in black and white
is yor dvd play pluged into the tv or is it pluged into a vcr if it is plug it right into the tv.
and are you watching a black and white movie
Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
Top Aiwa Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
john h
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
