At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
We had that problem and is was because we had the hose (which is long) too far into plumbing drain it would set off a syphon effect and stop. Then it would start the beeping
it sounds like the bearings are going out as it spins faster the noise quietens down because the bearings are more spread out and as it slows they fall lower leaving an area that it causing "friction" of a kind
