After changing the ribbon and printing 4 cards.
SOURCE: Datacard SP35 - High Temperature
If you want to "control" the temperatur on the printhead , you first of all need to install Diagnostic program for your printer.
On the menu go to values.
Find Ymck power, which probably is on 0. and try to adjust to MAX 50 or -50.
Push the : Save current values to power on , button.
The passaword is 42360..
SOURCE: Datacard SP35 + giving broken ribbon error
You have to clean the roller under the printerhead.
The big black one..
I suggest you install Diagnostics.
Go to motor test, and take the transport fast reverse. 300 sec.
Now you can clean the roller easy.
SOURCE: have a Pebble 4 card printer and the ribbon breaks after each card is printed.
the card are not being fed when printing a test card...
SOURCE: Ribbon is breaking constantly in every print of card
in order of most likely
1 edge to edge settings in printer tool box are off.
2. print ribbon carriage (blue part you put the ribbon on is bad)
3. Bad ribbon
4. dealer needs to service to calibrate print head temp
tulsabiz.net for more info
SOURCE: data card sp35 plus ribbon break
Three things to try,
1. Try actually flipping the cards over, on side may have a burr that is cutting the ribbon.
2. Try changing the position of print on the card. Most manufactors call this EC
3. Try calibrating the ribbon sensor from with in the driver or the datcard utility that is on the bottom right of you windows desktop
