If these are semi weighted keys here is a cut and paste from a manual:
19. Disassembling the Keyboard Assembly
* After inserting a round stick (Rod: TX000670)
between the frame and the keys, remove the
circuit boards. (Fig. 23)
19-1 GHD EBUS L, MK SUB Circuit Board
(Time required: about 12 minutes)
Remove the seven (7) screws marked [260A]. The
GHD EBUS L and MK SUB circuit boards can then
be removed. (Fig. 24, Photo 5)
19-2 GHD M Circuit Board
Remove the five (5) screws marked [260B] and the
screw marked [262]. The GHD M circuit board can
then be removed. (Fig. 24)
19-3 GHD H Circuit Board
Remove the four (4) screws marked [260C] and the
screw marked [262]. The GHD H circuit board can
* Keys can be removed without removing the
circuit boards.
* After removing the GHD EBUS L, GHD M and
GHD H circuit boards, and the rubber contacts
can then be removed.
19-4 Rubber contact
Remove the GHD circuit board for the involved key.
The rubber contacts can then be removed.
The rod is inserted above the weighted hammer and the bottom of the keys from one end. It appears to be about 1/4 inch diameter dowel and will run the full length of the keyboard. You might use 3 foot ones from each end.
Screws are removed and the boards removed without taking the individual keys out.
Testimonial: "Thank you for taking the time to help. Can't wait to get it fixed, thanks to your helpful information. I really appreciate it."
Note my previous comments are for the Yamaha NP30 but most of these use the same semi weighted keyboard.
It is likely your contacts are conductive rubber that press on the board. They likely just need cleaning.
Use 99% isoprophyl alcohol and Q tips to clean both the rubber contacts and the circuit board where they contact. Use ONLY 99% isoprophyl alcohol NOT rubbing alcohol or any other contact cleaner!!!!!!!
