F6 error is related with the indoor blower motor check the return signal wire of motor with the small connector and fix it properly.
How to solve my problem F6
Plz check the PCB card of indoor unit,might be relay not working properly.May be dry soldring or u have to change it.It will be ok
See get it checked , if the compressor is taking high amp then your comp is faulty.. aur there can be low refrigerant.
Every 3 months we should clean indoor unit by the service person ..water leakeage problem will be solved
I have facinng problem in onida split ac model 12 grl cooling is ok but out door compresor is not cut off
When ac start after 15 minutes show F5 and air-conditioning now coming cool air how solved problems
Where to check the return signal wire???
Must be relay change its ok.
Cheak relay running capacitor & starting capacitor change now comp. done
error code descrioption not mentioned in manual
error E1 is com
how to fix F6 error in voltas split when swithced on
showing f6 and does not start
whan we start the voltas ac f6 error show's on display.
HOW TO SOLVE F6 PROBLEM
blower moter is demege
Hey fault is display f6
How much solveOnida Split ac show f 6
