Location
Date
Local Time
DescriptionWhat's This?
MURFREESBORO,
TN,
US
03/17/2010
9:33 A.M.
DELIVERY
03/17/2010
4:06 A.M.
OUT FOR DELIVERY
03/17/2010
2:51 A.M.
ARRIVAL SCAN
NASHVILLE,
TN,
US
03/16/2010
10:30 P.M.
DEPARTURE SCAN
03/16/2010
7:07 A.M.
ARRIVAL SCAN
HODGKINS,
IL,
US
03/15/2010
7:56 P.M.
DEPARTURE SCAN
03/15/2010
2:08 A.M.
ARRIVAL SCAN
SAN PABLO,
CA,
US
03/11/2010
3:25 A.M.
DEPARTURE SCAN
SAN PABLO,
CA,
US
03/10/2010
11:49 P.M.
ARRIVAL SCAN
MARYSVILLE,
CA,
US
03/10/2010
9:43 P.M.
DEPARTURE SCAN
03/10/2010
4:26 P.M.
PICKUP SCAN
US
03/04/2010
1:00 P.M.
BILLING INFORMATION RECEIVED
Tracking results provided by UPS:
03/17/2010 2:08 P.M.
ET
Try this Make sure no game in ps3 turn ps3 off and by the switch at the back unplug it wait a couple of sec then plug it back in turn on buy the switch at the back then hold down power and eject hear a beep keep both preseec till 2nd beep let go should be able set it to ya tv
This is known as a overheating issue..People sometimes try to fix the problem by pulling there machine apart and reapply thermal paste to the cpu's...Some have got this method to work others haven't..You can send it in for repairs to sony cost around $150... Secondly you can try a another step turn off the console and unplug from the power,remove old hard drive and re-insert a new hard-drive. This step usually helps fix the blinking red light on PS3.
if it is a red light.... you have the ps3 equivalent to the rings of death on a xbox 360 meaning it had a serious system crash it has something to do with the gpu and cpu and you must send it back for a replacement as it is unfixable, here what the colors mean, red=dead, green=good, yellow=overheated
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
insetad of restoring the filing system, restore the default settings ore restart the system
The only thing i can think of is click the switch to turn off the PS3 completely leave it off for about 30 second turn the switch back on and try again. If the doesn't work you may have a problem with your power supply and might need to get your PS3 serviced
