There is one new firmware available here:http://insigniaproducts.com/products/dvd-players-recorders/NS-BRDVD.html
just download the firmware and follow directions to install it. One problem is that Insignia will not do a new update so any movies coming out with the new security feature on new Blurays will have problems playing.
Visit the insignia forums and post some messages or write a email to help get our players running for at least a little longer.
Thanks and feel free to comment with any questions at all.
Because the authoring schemes keep changing for Blu-Ray and the security keys keep updating, new firmwares are being released at www.insigniaproducts.com.
If the movies you have previously owned still play in your Insignia NS-BRDVD unit, but new titles do not, download the latest firmware and either burn it to a CD and load it into the player (an automatic process for updating the firmware) or save and extract the firmware on a USB thumb-drive (the easiest way to perform this), plug the thumb drive into the USB port on the player, and update the firmware.
If this does not correct the problem, take the player back to Best Buy to be checked or returned.
Check your setting. If that doesn't work exchnage the unit.
SOURCE: Will not play new movies. keeps rebooting to
If you are referring to "new" meaning recent releases, there was a change in the DRM and authoring scheme that was created by the releasing publishers. Several Blu-Ray players are having issues with this and solutions are being rolled out as quickly as possible.
The Insignia Blu-Ray players have solutions available as firmware updates on:
Search by your model number and download the latest firmware to a USB stick, insert into the player, follow the instructions, and you should be good to go. you should also receive updated applications like Netflix and Pandora.
Hope this helps.
