Wont drain now making a loud noise? Help!!??
That loud noise is most likely debris bouncing around inside your water pump. Pull the 2 hoses off and try removing it by hand, or un-bolt it from the floor pan and tip it sideways to shake any small objects out. I found a mans wedding ring in there once.
That's a great question, Roth!
Based off the information you have provided your Frigidaire washer is making a loud noise during the spin cycle. This could be an issue with your bel, motor, or tub. In order to find the cause of your noise you may need to disassemble your washer. This is not a simple DIY job and I would recommend contacting a technician to come out. This will help prevent any future issues or personal injuries. -Matt
Hi burwellkaren - Is the washer making a humming noise? If so, either the drainage hose or pump is clogged and needs cleaning. If not, then the unit may possibly be experiencing an issue with the control board not communication correctly, faulty pump, timer, door lock assembly or something more severe like a damaged tub. I will personally recommend contacting a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
