Optics Logo
Anonymous Posted on Mar 18, 2010
1992 vintage LX200 died while slewing in declination. Readout went to just ''Meade'', and handpad was unresponsive. No smoke, fuse is good. Tried hand-turning Dec., and ammeter showed increased readings. Opened all casings, no burnt cap.s, but one broken wire on Dec. board. Reconnected, now scope boots up, but only operates in RA. Dec. doesn't drive, nor does it show any position change on the readout. Where do I go from here???
  • Anonymous Mar 19, 2010
    Thanks, gingko, but, given their track record on customer service, that route seems abysmal. But you're right, I might just get surprised, and wouldn't that be nice!
Ginko
Level 3:
  • Master 19,396 Answers
  • Posted on Mar 18, 2010
Ginko
Master
Level 3:
Answers
19396
Questions
25
Helped
8073354
Points
55462
Hi.
I am answering because I see that the problem is still unsolved.
I think that the best thing to do is contacting Meade, so that they can tell you if it is the case to replace the pcb, or if it is just a setting problem.
Here the contact: Contact Us.
Regards.
Meade lx200 acf r manual
Many Meade telescope manuals are available here: http://www.meade.com/support/manuals/ . There are several models in the LX200 series. The manual for the LX200-ACF is here: http://www.meade.com/downloads/dl/file/id/11/product/0/lx200_acf_manual.pdf . There is also a model LX200-R; the manual for this model is at http://www.meade.com/downloads/dl/file/id/13/product/0/lx200_r_manual.pdf . I don't see anything about a model with both the ACF and R features in this series.
I hope this helps.
I have a 1998 Meade LX200 classic that blew out fuses and capacitor(s) when I recently started it up. I have had a local TV repair shop replace all of the capacitors and it now has a runaway RA drive when...
Something else is wrong. The first thing to try is a new DEC cable and a new hand controller cable for the runaway slew, and hand controller issue.
If new cables do not fix the problem then contact Ron Sampson on the Yahoo LX200 group-- just post a message for him there. He can repair Meade electronics at a reasonable cost if you send him the boards.
He can also repair the hand controller including the internal ribbon cable and the LCD screen.
Try the new cables first- check this web site for a wiring diagram:
http://www.mapug-astronomy.net/
or contact www.scopestuff.com they may have one already made-up.
1helpful
Scope is 12.5, 9 years old. We align by going to "named star," selecting one, slewing, correcting, hitting synch. Repeating with another star. Almost always the scope goes to accurately there after. (We...
Runaway DECLINATION is what this is called. Usually it can be fixed with a new hand controller cable. If a new cable does not fix it, then it has a blown motor circuit board and must be returned to Meade for repairs.
Meade customer service:
http://www.meade.com/support/index.html
Hello. I just bought an older, used Meade LX200 18...
The scope will run just fine on 12 volts. www.scopestuff.com sells the cigarette lighter cord for that telescope.
Call them here:
www.scopestuff.com
May 16, 2010 • Optics
My Meade LX-50 telescope has developed an electrical problem. When I turn it on it immediately blows the fuse. I tried disconnecting the drive motors, and it still blows the fuse, so I think the problem is...
A fellow by the name of Ron Sampson can repair hand controllers and main boards on Meade telescopes. He does very good work. All you need to send him are the board(s).
You can contact him by posting a message on the Yahoo LX90 or LX200 group forums.
http://tech.groups.yahoo.com/group/lx90/
Good luck-- by the way he repaired the hand controller for our astronomy clubs 10 inch Meade LX200, at a very reasonable cost.
I cannot get my Meade telescope to slew in declination at all-either locked or unlocked using my Autostar device.
Need more information --- what type of Meade scope do you own. Name and number?
You can also call Meade Customer Service for help.
1helpful
2answers
I've made every possible alignment on my 10 inch Meade LX200GPS telescope, training,set-up, calibration, etc...but when I slew to a star....it is ALWAYS very far off in Dec....though RA seems to be well...
You might want to join the following Yahoo group:
http://tech.groups.yahoo.com/group/LX200GPS/
I am not familiar with the LX200, but there are probably folks on the Yahoo group that can help.  The only thing I can think of is if you are using a wedge and the wedge isn't at the correct angle (should match your lattitude).  Or you are not using a wedge and the Meade controller thinks that you are.  But one would think the calibration would solve that.
3answers
Problems with my LX200 Classic
C1 and C2 are on the input of a voltage regulator. The fact that they burn, could mean that their voltage rating has been exceeded (check the voltage across them), or that age has caused their failure. The classic uses about 18 volts into the power panel - see that it is not higher than that. The handpad would not be a cause for this to happen as it is not the source of the power. Replace the caps with similar ones, but with higher voltage rating - 50v is fine. But check your power supply first!
1helpful
Problems with my LX200 Classic version
Cannot power up my Meade LX200
Check to make sure there are no bad connections under the swith itself. My Celestron C8 mount has similar problems and if I mess with the switch it will power up.
Top Meade Optics Experts
ADMIN Eric
ADMIN Eric
Tony Parsons
Tony Parsons
Are you a Meade Optic Expert? Answer questions, earn points and help others
