WHEN SPINING MAKING A LOUD NOISE WHERE CAN I GET SOMEONE TO COME OVER AND TAKE A LOOK AT IT OR IS THERE SOME WAY I COULD TROUBLE SHOOT IT AND FIX IT
I LIVE IN I91 QUECEC RD I SLAND PARK NEW YORK 11558
Your drum bearings have gotten water in them from the lip-seal on the drum drive shaft,you need to remove the rear access panel,remove the belt remove the pulley,then remove inner tub and remove the spider that holds the inner drum on,then remove old seal and replace the inner and outer bearings,dont do just the inner bearing as the outer one isn't that expensive and may go out later,and its very labor intensive,anywhere from 2 to 7 hours depending on how stuck the old bearings are in the machine
