The error is displayed.
Can somebody tell me the key sequence to get into maintence mode
on the Brother 115c. and reset the purge counter.
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Brother DCP110c Reset Counter
1. unplug at side of unit, switch on while pressin menu2. Enter 8 press set enter 0 press set
" by using the up arrow key & SET keys."
3. press the mono start key several times untill the purge count appears on the LCD.
4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero (like in 1)
5. press the stop/exit key to return to the initial stage of the maintanance mode.
6. enter 9 twice by using the up arrow & set key’s to exit from maintenance mode
grandpaben !
I used this for DCP115C. Found it hard to get into maintenance mode with other person's directions. These directions were much easier. Thanks
fantastico!!!!!, thanks heaps, saves me buying another machine, save the environment.
Works great!! Thanks!!
MY bROTHER DCP-115C Always says Unable to clean see trouble shooting and routine maintenance at Users Guide, i want only a guide to reset my printer so that could be able to clean by itself
thanks,
Mr, Elpidio Concepcion
I need your help how to reset cleaning limit for my brother dcp-115c. error displayed unable to clean...thanks
Perfect!! it solved my problem.
Thanks for the big help.
Unable to clean
Brother Service centre 603-7884 9999
Minimum charge RM30 without repair.
Thanks a lot for helping. I tried your description, and problem is solved. I found the "maintenance menu " on the screen a little bit diffuculty, first of all unplug the cable, then press the menu button and the same time plug on again without release the button. You can follow the description after screen turns the "maintenance menu".
unable to clean
unable to clean error msg shown in LCD display -brother model DCP-115C
Says Unable To Clean on printer. Have been unable to follow instructions on resetting.
Cheryl.
Unable to clean
unable to clean
unable to clean troubleshooting and routine maintenance chapter in user's guide
can you help how solve my problem with my printer.error unable to clean on brother dcp-115c.
thanks...this is my email add [email protected].
unable to clean
can you help how solve my problem with my printer.error unable to clean on brother dcp-115c. please email me the intruction how to clean itslt my priner to my email add [email protected]
Please tell me how to solve my problem on my brother dcp115C. Unable to clean plug. After thourough cleaning, problem still persist.
Error message keep appearing in my printer,"Unable to clean, see troubleshooting ang maintenance chapter in user's guide." Followed instruction on manual but cannot solve the problem.
Light flashes " unable to clean. See trouble shooting and maintainence in manuel." I cant find my manuel what can I do.?Â
My printer DCP115C have same problem.
