Apple iPhone 3G Logo
Dev Mehta Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Iphone 3GS wifi is having problems. The wifi search circles comes up but it doesn't give me options for networks to be picked. And my home wifi is perfectly fine. how do i get this fixed? . My wifi is "on" it just does the search cycle over and over. please help.
Tim Digibrain
Level 3:
  • Master 846 Answers
  • Posted on Apr 26, 2010
Tim Digibrain
Master
Level 3:
Answers
846
Questions
0
Helped
1310040
Points
1356
I would try a software restore first. If that doesn't fix it bring it to Apple. If Apple doesn't replace it for you, you can find the logic board at iPhone 3GS Repair and there is a guide that shows you how to put in the part at iPhone Repair Guide.
How to unlock iphone 3gs for free?
To unlock an iPhone the remote unlock service would be a better option because, you need not give your mobile to someone else nor do you have any chance to enter the wrong unlock codes. To get such an unlocking service for your iPhone 3GS approach Wickedunlock.com and by submitting the country and network to which the mobile is locked to you will be able to remove the restriction from the respective network. This will be a permanent unlocking solution.
1helpful
My iphone 3gs wont pick up my network
You may be in a dead zone for your network. Try holding down your home button and lock button at the same time for about 10 seconds. That will restart your iPhone and should fix the problem!
I phone 5
What Type/Brand of router ?????
Apple's iPhone is a multimedia connectivity tool.
As such, the iPhone employs a sophisticated system to keep you connected to the web via WiFi signals so that you can stay up to date with email, mapping and media.
To use the iPhone's WiFi feature just follow these steps.
Tap a network.
If you have not yet used your iPhone's WiFi or if you're in a new WiFi area, the iPhone will show you a list of available networks.
Tap the network that you want to connect to in order to connect.
If there is a password required a little lock icon appears.
Enter the password to connect to locked networks and continue to surf the web.
Monitor your signal.
As you use your iPhone, especially if you're moving around, you should take a look at the signal strength of the connection.
The strength is indicated by a small, black broadcast symbol that stacks arches, or rounded bars, on top of one another.
The more bars there are the better the signal.
Make connecting to WiFi automatic or manual.
The iPhone is equipped to automatically search for available networks and connect you to one.
If you do not want the phone to search for networks, select the "WiFi" option on the phone's menu.
Then select either the on or off option of the "Ask To Join Networks."
Turning this option off requires that you find networks manually.
Forget a network.
Once you connect to a WiFi network once the iPhone automatically remembers the network and connects you to it at a later opportunity.
To forget a network so you don't get automatically connected choose the "WiFi" option on the menu.
Then tap the right arrow button next to one of the networks that the iPhone already remembers. Then tap "Forget This Network" to erase the phone's memory of the network.
Troubleshoot Wi-Fi Connection Problems on an iPhone
If you experience Wi-Fi connectivity issues on your iPhone, you may need to reset the Wi-Fi connection.
Your connectivity issues could be caused by the wrong password if you are having trouble logging into the Wi-Fi network or from a problem in your iPhone's settings.
By resetting the Wi-Fi connection, you are clearing out the previous settings created when you first connected to the network.
Tap the Settings icon on the iPhone's home screen, and tap the Wi-Fi tab.
Swipe the switch on the Wi-Fi tab to ensure Wi-Fi is enabled on your iPhone.
Tap the blue arrow button on the network tab you are connected to in the network list, and tap "Forget this Network."
Tap the "Forget Network" button that appears on the pop-up menu to confirm the action.
Tap the Wi-Fi Networks tab in the upper-left corner to return to the previous screen, and tap the network's tab in the network list to re-join it.
Press the Home button on the iPhone, and tap the Safari icon on the home screen to test the Wi-Fi connection.
Tap the blue arrow icon on the network's tab if the connectivity problem persists, and tap the "Renew Lease" button at the bottom of the network's window.
Tap the "Renew Lease" button on the pop-up box to confirm the action.
Tap the Home button on the iPhone, and tap the Safari icon on the home screen to test the network connection.
Iphone 3gs stuck at loading and even after restart and reboot. Try to reinstall to latest update but same problem arise. Please help.
Hold down the home button (circle button on front) for around 6 secs and plug into comp still holding button (with itunes loaded up) itunes should then bring message up saying an iphone has been detected in recovery mode (release button) and gives you option to restore, select restore and follow steps through to restore your iphone as a new iphone or from a back up
** if you restore from new you will loose ALL data on your phone but if you restore from a back up then you will get all data back onto your iphone **
My iphone 3Gs touch pad isn't responding. Tried restarting by holding down sleep and home button till apple logo appreared, yet, iphone isn;t responding.
the touch pad of iphone 3gs is given a problem.tried to reset it..but wen general option comes up and we have to choose the reset option,cannot scroll down to get the option..what to do??
My Iphone 3G won't connect to home wifi after working well for months. In settings, it searches indef. for networks. 3G works fine. My husbands iphone works fine. Any suggestions?
you can try to set your wifi same as your husband's one, check the wep code and wifi shold be enabled.
try this and give feed back!
good luck
My IPhone 3gs connects to my home network but doesn?t actually send and receive data. It shos the wifi on the top cannot able to acess the internet.
Check, is your PC has connected properly on network?
You have to also allow this application in Firewall Exception list. If firewall blocked it then unlock it.
Your problem must have to solve now.
Thanks.
Happy to help you.
2helpful
2answers
Iphone 3G-S will not connnect to BT Home Hub 2.0
First, Can your 3GS connect on ant other Wi-Fi? If so the issue is specific to configuration on either iPhone or BT Home Hub.
Second, Does BT Home Hub configured for any kind of mac-address security? Check that, if it does either remove it or add the iphone mac-address, you can find the iphone mac address under network setting.
Third, Does Home Hub have limit on number of devices that can connect to it, some do. check that and make sure that you increase the limit or just remove the restriction altogether.
Fourth, IS BT Home Hub Wep enabled? If so the password/key you are entring on your iPhone must be exactlythe same. Or just remove the wep encryption to see if your iphone 3GS can connect.
Fifth, If your old 3G is able to connect to your BT Home Hub, then just make sure you are not FAT fingering the keys and entering a different key.
Wifi on iphone 3g is not picking up wifi signal
it may be finding it but not showing the passcode screen to enter your wep key.
tap the wifi settings and set you network information and the wep network key which is located on your router.
If you put any other code in your wifi won;t connect.
1helpful
5answers
Iphone wifi
You need to select the 'Settings' button on the home screen, then make sure that the 'Ask to Join Networks' option is turned on. Choose your network, and then enter in your password. I've had the same problem before, and it turned out that my phone wouldn't connect without setting the computer to require a password. If this doesn't solve your problem, please let us know.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
