Motorola Mobility RAZR V3 Logo
Posted on Mar 10, 2008
Unlocked european phone MMS
Hi, I have a european phone that will not send/receive photos MMS or connect to the internet...ATT tried to help me with it by walking me through the programming but it still won't work...they suggested i talk with motorola about it. Thanks!
Merala
[email protected]
  • HAMZA ASSAD May 13, 2008
    i want unlock my phone
  • Anonymous Mar 21, 2014
    I am unable to get internet or send photos on my samsung gt-e2220, I have had the phone for around three weeks and I have tried everything!!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
463
Points
Wrong! ive got an unlocked european phone and i got these settings that cingular WOULD NOT give me off the net
-= MMS Web Session =-
Menu -> Web Access -> Web Sessions -> Menu -> New
Homepage: http://device.home
Service type 1: WAP
Gateway IP 1: 066.209.011.061
Port 1: 9201
Domain 1: (blank)
Service Type 2: WAP
Gateway Type 2: 000.000.000.000
Port 2: 0
Domain 2: (blank)
DNS 1: 000.000.000.000
DNS 2: 000.000.000.000
Timeout: 10 minutes
CSD No. 1: (blank)
User Name: (blank)
password 1: (blank)
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: wap.cingular
User Name: [email protected]
Password: CINGULAR1
-= Message Setup =-
Main Menu -> messages -> Menu -> Message Setup
MMS Message Setup (This is very critical)
Inbox View: Sender
Srvce Center No: +13123149810
Auto Cleanup: 5 days
Email Gateway: 36245
SMS Alert: On
Use GPRS: Yes
-= MMS Message Setup =-
Main Menu -> Messages -> Menu -> Message Setup ->
MMS Message Setup -> Server Info -> Menu -> New ->
Service Name: CINGULAR MMS
Server Name: http://mmsc.cingular.com
Web Session Name: (Choose the Web Session you created for MMS)
set to default
A
Anonymous
This worked well Thanks :)
A
Anonymous
Service type 1: WAP
Port 1: 9201
Domain 1: (blank)
Service Type 2: WAP
Port 2: 0
Domain 2: (blank)
Timeout: 10 minutes
CSD No. 1: (blank)
User Name: (blank)
password 1: (blank)
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: (blank)
Password 2: (blank)
Speed (Bps) 2: 9600
Line Type 2: ISDN
Password: CINGULAR1
-= Message Setup =-
Inbox View: Sender
SMS Alert: On
Use GPRS: Yes
set to default
Anonymous
Level 1:
  • Contributor 51 Answers
  • Posted on Mar 12, 2008
Anonymous
Contributor
Level 1:
Answers
51
Questions
17
Helped
17164
Points
78
If its an unlocked phone there is nothing you can do about the problem unless you go back to the original service provider.
Good Luck :)
Regards,,
Sophiee.,,
How to open mms
mms (multi media messages) like photos or videos that are sent like a sms to a phone and do not require internet access to send/receive.
How to open = It depends on your phone and your mobile service provider - you need to configure your phone to receive/send mms (just call your service provider they will help to setup).
Better yet - if your phone has access to internet use whatsapp or viper apps to send or receive photos/videos. Its a much more easy than mms
Oct 01, 2016 • Cell Phones
HELLO I HAVE A PROBLEM WITH MY CELL PHONE IS A LG GW305 I CANT GO TO THE INTERNET AND I CAN SEND AND RECIVE MMS SO IF U CAN HELP ME WITH THIS and if u can help i wan to use for att but i cant ...
okay if you can send and receive SMS/MMS your configuration is hooked up........for internet use you will need to contact ATT (you need a data plan)...once you get that... Internet will be one touch away... its already set up if you did not change it........
I bought the phone in mexico from the company TELCEL. Came to live in the UK, had it unlocked and got the new sim card but cant send photo texts or connect to internet. I have been told I will prob never...
You have to contact your service provider to receive the GPRS and MMS configuration messages on your phone.Once you have received it, you have to save them to your phone.Now you can access the internet and send photos and videos via MMS on your phone.
83helpful
3answers
Have samsung b3310 but can't receive or send pics on ATT
Try these they worked for me & I have the same phone:
MMS settings:
Menu --> Messages --> Settings --> Multimedia Messages --> MMS Profiles --> Options --> Create --> Profile Name: AT&T MMS, Home URL: http://mmsc.cingular.com, check the box next to "proxy", IP Address: 66.209.11.32, Port: 80, Linger Time (sec): 90, leave DNS box unchecked, Bearer: GPRS then go to Advanced Settings --> APN: wap.cingular, Login ID: [email protected], password: CINGULAR1 (case sensitive). Hit "save" twice, then "options" then "activate." This will activate your MMS so you can send and receive picture messages.
WAP settings:
Menu --> Internet --> Settings --> Browser Profiles --> Options --> Create --> Profile Name: WAP Profile, Home URL: http://device.home, Proxy: check box, IP Address: 66.209.11.32, Port: 8080, Linger time (sec): 90, leave DNS box unchecked, GPRS --> Advanced Settings --> APN: wap.cingular, Login ID: [email protected] (case sensitive), Password: CINGULAR1 (also case sensitive). Hit "save" twice then "options" then "activate." This will allow you internet access.
Hope this helps!!
Help with mms on ks360
if you are using an unlocked device on at&t's network you will not be able to ever send/retrieve the mms messages, the reason for this being that at&t does not support the use of internet on an unlocked phone, and in order to send/retrieve the mms messages you must be able to connect to internet.
Jan 13, 2010 • Cell Phones
Cannot send or receive multimedia messages it say when i send it cannot send will try again later and when i try to open a mms it says unable to open
It might be that you dont have internet connection turned on.
Call ATT tech support at 611 and ask if your internet is working.
1helpful
LG Shine CU720 -cannot access the internet or mms-unlocked phone from Telstra
if MMS is blocked then the internet for sure will be locked they run off the same
Lg shine tu 720
if you need it set for att email me and ill send the settings to [email protected]
Can't send or receive MMS messages
I work in TSD for ATT , and from multiple cases like this , customer do not know that ATT requires that all PDA phones do require a PDA data package , without this you will not be allowed to send or receive MMS messages.
2answers
MMS settings for W850i
Do you have the MMS message server configured properly?
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
