Vivitar DVR518 Camcorder Logo
Posted on Mar 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DVR 518 question regarding sd card compatibility;- will the product accept a SDHC card to 8gb I have difficulty in getting a standard SD card
Glyn Kendall
Level 2:
  • Expert 146 Answers
  • Posted on Mar 19, 2010
Glyn Kendall
Expert
Level 2:
Answers
146
Questions
0
Helped
53193
Points
435
The manual is not very precise but you cannot get normal SD cards that go to up 8gb, the highest is 2gb.
When they say 8gb they must mean SDHC.
Hope this helps.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 11, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
273
Points
Here is a site that claims all of these cards are compatible with vivitar dvr508 and most are sdhc cards http://www.mymemory.co.uk/compatible-memory/Digital_Camcorders/Vivitar/Vivitar+DVR-508_Memory_Cards
1helpful
How do i get an 8gb sd card to work in my vivitar dvr-530 cam corcoder?
The DVR-530 works with SD cards, which max out at 2GB. Your 8GB card is actually an SDHC, not an SD card. While SDHC cards fits into the slot, they are electronically incompatible and will not work in this camcorder. You need to use SD cards, 2GB and smaller.
Sorry if that wasn't the answer you wanted to see, but that's the way this camera works.
Hello, I have bought an adapter micro sd xd adapter for an old finepix f10 photo camera. I have tried more micro sd card 2GB, 4GB, 8GB with this new adapter, but is is not working in my finepix f10. It...
Your Finepix F10 does not support SDHC (High Capacity) memory cards.
You can only use standard SD cards with a maximum capacity of 2GB.
New technics are not always backwards compatible, sorry for that.
Jul 21, 2011 • Cameras
The only sd card i can find locally is an 8gb marked PNY SD HC it says on the packaging that this is new technology and only compatible with SD HC host devices. Is this card suitable for the Vivitar...
To be correct, the 8GB card is not an SD card but an SDHC card.
The 925DVR can use both SD and SDHC cards, up to 32GB in size. There should be no problems with the PNY card.
Just got it dont how to set it up and cant get videomode or to turn off or on is my sd 8 card shot
Do you mean 8GB SD card? There are no 8GB SD cards. Any card that size is an SDHC (High Capacity) card.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC cards. SDHC is not backwards compatible.
1helpful
What is the maximum SD size that will work with the DSC-4500Z camera?
The manufacturer of your camera specifies SD card compatibility without providing a specific number. This is not uncommon however, as the maximum size for SD cards is 2 GB. Cards that have a larger capacity than 2 GB in the "SD" format are "SDHC". Read the label of these cards (that have a larger capacity than 2 GB) that *look* identical to SD cards, and you'll see that they are in fact SDHC types. The SDHC card can have a capacity of up to 32 GB. A device that is compatible with the SDHC specification should be able to read any SDHC card *and* any SD card as well; because the standard requires "backward compatibility" to the older SD standard. A device that accepts SD cards should be able to read any SD card, *but* if an SDHC card be introduced to it, it may provide unreliable results (from being able to access only 2 GB of the capacity or not recognizing the card at all). Make sure your pictures are safe and don't get lost; use only SD cards in this camera.
I hope this helps!
1helpful
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
7helpful
3answers
My Kodak P850 do not accept SD cards 4 or 8GB, error message state that memory must be replaced. No way to format the SD in camera. How can I do that camera accept the SD card
Technically speaking, SD cards only go up to 2GB. (Actually, some very rare 4GB SD cards exist, but I doubt you have one of those.) Cards 4GB and up are SDHC (Secure Digital High Capacity) cards. Your camera was designed before the SDHC specs, and thus is not compatible with SDHC cards. This is not something that can be changed in firmware, since there is a hardware compatibility issue.
SDHC devices will accept SD cards, but the opposite does not hold true. SD devices will not accept SDHC cards.
4helpful
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
2helpful
It doesn't read 8gb sd cards on internal sd drive
There are two types of SD cards. The first, standard type, had a capacity limit of 4GB. But quite soon the technology advanced and higher capacity Flash memory has been developed, so the standard had to be revised - and SDHC was born (HC stands for High Capacity), which includes cards having 4GB and above.
There is an overlap, as you can see, because there are 4GB CD cards, and 4GB SDHC cards on the market.
Now your DELL is an older machine, and it's card reader is not compatible with the new SDHC standard. And it will not be, even with a BIOS update.
You have two options: find a 4GB SD card (they are hard to find, majority will be SDHC) and stick with this capacity, or purchase an USB SD/SDHC card reader, which is cheap, and use it to transfer files to/from your 8GB card.
8GB SDHC Cards
Your camera will accept a maximum SD card capacity of 1GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 1GB capacity.
Top Vivitar Video Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
