Whirlpool Duet GHW9150P Front Load Washer Logo
Anonymous Posted on Mar 19, 2010
Just have a question...The feature "Add a garment" - does this mean I have to add a garment because the setting I am using needs more load or does it simply means adding a garment is fine anytime while that feature is lighted with a green..
Anonymous
Level 3:
  • Master 569 Answers
  • Posted on Mar 19, 2010
Anonymous
Master
Level 3:
Answers
569
Questions
0
Helped
195954
Points
1789
There is no minimum load requirement - it just means you can add a garment or garments if you wish.
Testimonial: "Very helpful - Thanks much"
Marvin
Level 3:
Top Expert:
  • Whirlpool Master 85,242 Answers
Marvin
Whirlpool Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024952
Points
266281
No it interupts the wash cycle and unlocks the door so u can add more clothes to the wash, then the wash cycle continues.
Washer making a clicking sound, the tub isnt draining, and the add a garment stays on
Door switch isn't making. .if door isn't closed the washer won't run and will have the add garment light will stay on.
F4 add garment washer wont unlock
Hi.
F4 means that there is a problem with the pressure switch.
Please read the article here: This tip applies to Whirlpool built washer, including Kenmore and other brands. F4 means ...
Regards.
Ginko.
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
2helpful
Can I use bleach --if so how do I add and how much
you add bleach to the detergent and wash the garments in both. So start filling the washing machine drum, add the perscribed amount of detergent, then add the bleach, let the 2 agitate together and then add the garments. This dilutes both so that they don't damage your clothing. usually it tells you on the package how much to use, however usually a "Cap Full" will do...
1helpful
Kenmore h2 error code
I have a whirlpool ghw9100lw the light is flashing but it will not start
1helpful
2answers
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
7helpful
2answers
Won't restart or clear off
try unplugging for a few min adn replug see igf that clears the computer, you didinbt by chance force the door open to addd a garment didi you??? if so the door lock has probalby beed compromised
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
