Sanyo dp52848 My tv made a popping noise and then shut off wont turn back on, no leds on, was plugged into a surge protector reset the surge protector all other components work, tv still doesnt work.
its a sanyo tv doesant it have any kind of reset or fuse for protection agaienst a power surgeits a sanyo tv doesant it have any kind of reset or fuse for protection agaienst a power surge
You can't post conmments that contain an email address.
Re: my tv made a popping noise and then shut off wont
Power Supply Board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Testimonial: "power supply board had a couple blown resistors. Thank you"
You cannot change the aspect ratio. When a program is transmitted in 408i you will get a small picture in the center of the screen surrounded by black bars. This not the fault of the TV. You can try using the zoom feature, but the picture clarity will suffer.
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
If you wish to get more details about firmware update, check this link. It has firmware update procedure to many model TVs, with illustrations. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in thebrand name and model number to of your set, to its search box, and
press 'Enter' or view it in Mosaic / Timeslide
option.
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
When the set is turned on, the computer senses that something is wrong and immediately shuts the set back off. The standby LED will then blink a code, a certain number of blinks, to indicate exactly why the set was shut down. It is possible that your audio output IC is shorted, as this would make a pop or strange noises in the speaker just before the set shuts down, which it does to protect your speakers from burning up. The set should be looked at by a qualified tech familiar with Sony TV's.
