2004 Ford Freestar Logo
Posted on Mar 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Made a small thump under my feet when i tried
Made a small thump under my feet when i tried to start it and right away guages went crazy and it would'nt start. It also drained the battery
right away
Anonymous
Level 3:
  • Master 3,489 Answers
  • Posted on Mar 19, 2010
Anonymous
Master
Level 3:
Answers
3489
Questions
0
Helped
1159217
Points
10709
This sounds like the starter grenaded. Look under the vehicle for the starter and if the solenoid itself had come apart, it would act like a dead battery. Let me know what you find.
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Thumping noise
Could be the airbox touch the strut bar, there have been a few cases of that so check with hood open (park brake on) start and look close to make sure not touching anywhere.
Also have been reports of failed engine mounts so look at those closely.
2answers
Truck won't start but turns over
start with the simple. the thumping check the starter make sure it in right and bolted down. now change your fuel filter then check fuel presser
Odometer and gas guage wont work they r stuck right in the middle
This could be your alternator starting to go bad, happened to me once, all my guages went crazy. It doesn't cost anything to have it checked at the Autozone store here.
1helpful
I'm trying to guage whether my engine is dying
Was the the issue there before the new timing belt. It may be off a couple teeth. Do you have the correct type sparks plugs and the correct 02 sensors or some universal,splice in ones. When warmed up it goes into closed loop and the 02 sensors take over part of the fuel stratagy.
1helpful
Suspension noise
This noise is ussually right under your feet,It will need new stabalizer bushings and brakets.
2answers
All my guages went out at the same time...windows
sounds like alot of problems, have rolled into 1, without looking at it with my eyes, could be the main electric box that has just packed in
2answers
Guages when crazy. Now won't even try to start.
You likely have it repaired by now but it sounds like a classic case of oxidized battery or cable connection (sometimes mis-diagnosed as bad battery but cured with new (clean) battery)
Kia 4wd noise
cv joints maybe ball joints maybe transfer case but i dont think it is
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
