the i880 & the i885 needs a quality charger, if you get a original Motorola charger IT WILL WORK. There are some aftermarkets that will work, but not many.
solution to this problem is that the USB is on the connector
its an accessory
Data & Connectivity for the i880 by Motorola (Choose a different phone) Motorola USB Charging Data Cable - Item # NNTN5405
Easily link your phone to the USB connector of a computer or PDA, use your phone as a wireless modem and more. The cable also features an integrated charging port so the phone can be charged while simultaneously performing data operations. The charging port can be used with compatible standard, rapid and vehicle power chargers.
You can visit your nearest Sprint/Nextel service and repair location. If they have the flip in stock, they will be able to repair it right on the spot. Charges may occur if you don't have the service and repair plan.
i had a i730 that i drop in water i took it apart an took the blow dryer set it on hi about 8 to 10 " away from the parts put it back together it work just fine till i drop it out of the window of the mail truck. yes you can buy the main board
ps the i880 is a lot easier to work on then the i730
Very Simple Solution. I have the same phone.
First you need a Data Cable that connects your phone to a USB port on your PC.
Secondly, go to http://idenphones.motorola.com/iden/support/software/html/mp3_software.html
and download the mp3 loader.
Its very easy to use. good luck.
btw, I found a data cable on ebay for $5
