Our Toshiba laptop was dropped on the ground hard and broke the screen and broke the outside of the cd drive off. I want to know if it's worth fixing and how much it's cost
take it in for a proper diagnosis
It is possible that when you dropped it , you have jarred the hard drive and it is now not reading the disc hence the request for the boot /reboot request
Yes. Your laptop is far worth fixing. If you can do it yourself, open the back cover where your hard drive exists to make sure it did not get out of position (Probably due to shock during travel)
Then using a windows xp installation cd, run the laptop from the cd and when the setup screen reaches the point of "pressing enter to continue installation, or "C" for a recovery, pre C to go to the DOS prompt screen. On that screen, use the command >CHKDSK and press enter..
It should detect to disk and fix it for you. If it wont detect the disk, then probably you damaged it and need to replace it. You will have to go to a store to purchase one.
Apparently you damaged an internal component.
Your BIOS program performs a POST (Power On Self Test) on each of your computer's devices before it will allow the operating system to boot up. The POST protects your computer from damage to more devices if it runs into a fatal error with one.
I suspect that your hard drive may have been damaged. Hard drive is not the first thing checked, which would account for the few seconds that the POST runs. And, hard drives are easily damaged.
SInce your POST shut down your computer so early, it's hard to tell what else might have been damaged, but I would think it would be worth replacing the hard drive and trying to boot the computer up again.
Sounds like a bad hard drive to me. Take out the hard drive completely from the laptop and boot up with the windows xp cd and it should go past the blinking cursor. At that point you know you'll need another hard drive.
If there is anything on the hard drive worth saving, I would remove it right away and buy an external hard drive enclosure and connect it to another computer and pull all of the important files off of it. Although it might not be readable, if the hard drive has failed.
If you don't care about anything on the hard drive. Then and only then would I attempt to format it. Many ways to do this. With the Recovery Disc (which comes with many computers), a Microsoft Windows install disc, BartPE disc (free), Linux Live CD (free), etc.
Just let us know what OS (operating system) you want to put back on this computer and how you want to do this. And what kind of Windows install disc that you have (i.e. Recovery, MS Windows, etc.). And if you have access to another computer with Windows XP and a CD burner.
And right now, it does sound like your hard drive has failed. And if reformatting and reinstalling isn't going to work if this is true.
You most likely have a faulty hard drive, especially if it is making a clicking sound.
You wil need to purchase a new hard drive and install Windows again with the Toshiba Recovery CD.
sounds like a hardware problem....if u know how to assemble the laptop.it will be easy for u to fix that problem....all that things are connected to the mainboard..re insert all the cables what is loosen...regarding the headphone jack,if you have an extra jack you can replace that by resolder.
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
