Hobart HL600 Legacy Stand Mixer Logo
Posted on Mar 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hobart mixer I have to write a class paper on how to use, care for and clean a hobart mixer, due on Thursday, March 13, 2008.
  • 1 more comment
  • audreym Mar 12, 2008
    I am taking a food services course and need to know the general use, care and cleaning proceedure of any hobart mixer. I'd appreciate any information you could help me with. The kitchen I work in has 2 sized bowls - 20 and 60 i think.
  • audreym Mar 13, 2008
    Thanks so much for your quick responce, I tried to get info from other sorces without any luck, Thanks so much, I really appreciate your help.
  • Anonymous Feb 12, 2009
    how to change oil on 60 quart mixer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1146
Points
What kind of oil does a hobart mixer model # h600t use?
Anonymous
Level 3:
  • Master 640 Answers
  • Posted on Mar 12, 2008
Anonymous
Master
Level 3:
Answers
640
Questions
Helped
441001
Points
1475
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
  • 1 more comment
  • Anonymous Mar 13, 2008
    O.k.--Lets go with a hobart p660.These mixers are 60 quart bowls generally used in pizza shops.They have two speeds (1st and 2nd).The user puts his/her ingriedents (flour,yeast,oil,sugar,ect) into the bowl and raise the bowl.The user would then put the amount of time for the mixer to run,the start button is pressed and the mixer mixes the product for the set time.The operation of the mixer--------these mixers have saftey devices installed so there are no accidents.They have a bowl guard which is a cage that slides around the entire bowl preventing a mixer to start if its not closed.Another is a bowl height switch,which is the bowl has to be all the way up for the mixer to run.These mixers are the best and have always been superior to others.DONT OVERLOAD THE MIXER!!!!!!!!This is the most common way to damage the mixer or changing speeds while its running.When mixing dough only use 1st speed.If you use higher speeds you will damage the transmission sooner or later GUARNTEED!!!You can use higher speeds for cake batter,salad dressing,sauces, But any heavy dough 1st speed.Maintaining the mixer is easy---Dont hose it down or get it wet---Have the oil changed or check up every year---Keep ti clean and remove the dough hook every day and clean--If you hear a noise and something doesnt seem right with the mixer ,call for service because running it could and most likley cause extensive damage.Hope this helps.
    Glad i could help.
  • d eu
    d eu Apr 10, 2019
    Anthony, do, you know of a source that I could purchase a j-hook for a hobart C-210?
What does 0c3 mean in Hobart mixer HL600
It is overcurrent issue due to low supply volt or batch size too big or VFD is faulty.
2answers
Hobart mixer
hi Gassman, below you will be able to find a link on parts assembly for the mixer, you will have an idea on how to tear off the parts, get them cleaned and place them back, like a regular maintenance.
Hobart A200 Mixer Parts Assembly
More parts assembly for Hobart A200 Mixer
hope this helps.
What does 0c2 error code in Hobart mixer HL600
It is over current issue due to low supply voltage or batch size too big or frequency drive shorted.
What is a good source for a reasonably priced 200-240V 2.7 HP switched reluctance motor found on Hobart's HL600 mixers?
Baldor no longer manufactures that motor. Hobart would have to install a kit that includes every electrical component in the machine. Be careful if you find a used one, they have a very fragile encoder on the rear of the motor.
HELO I recently purchase a 460V H600T hobart mixer 2.5 AMP/ 3 PHASE but unfortunatly our bakery only provides 110V or 220V what are my option??
The machine can be internally rewired for 220 3 phase. Call your local Hobart office and have them come out and take care of it.
Mixer just hums, does not turn
has the armature worn down so the insulation is higher than the copper plate which the brushes run on,if so trim down to below plates
4helpful
2answers
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Where can I get a manuel for my hobart D-340 mixer?
What kind of manual do you need. The service manuals are only given to Hobart technicians while they are attending training classes for that paticular piece of equip. I have a parts manual w/ exploded views if needed. A operators manual/guide can be downloaded from Hobarts website. You will need Model, Serial & ML # or spec #.
Old 10 quart hobart mixer is smoking after 1 minute running what would cause that
my guess is the motor is on its way out time for a new one ?? hope this helps and be careful where there is smoke there is fire regards Jim
1helpful
3answers
N-50's need restoration
im a hobart service tech and service these mixers alot.the usual suspect problems is the tumbler assembly.service manuals from hobart---good luck they dont release them.i can help you out,
Top Hobart Food Mixers Experts
vince
NOEL
NOEL
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
