Re: ignition coil spark is weak. And where can i find
FIRST check the gap of the flywheel magnet to the magneto coil. Use a business card as a spacer and adjust the gap. If unit has points rather than electronic triggering, check those and timing and gap.
coleman 6250, AC power generator gas. 10HP
WX 6250???
does it matter with 2 pins, no.
I just sold one , last week.
100% perfect.
and have full documents on it. i came with manual new in box and wiring and parts list there, lost the manual did you already?
the one switch on most gens is SPST , 2 PIN SWITCH.
IT JUST KILLS SPARK..
IS THAT THE REAL MODEL # OR JUST WATTS
ALL GENERATORS HAVE TAG AND SHOWS TRUE MODELS#
this can be caused by a weak battery check battery and charging system to verify a good working system. it could also be a weak coil not being able to supply enough output voltage for the ignition system. you don`t say if its weak coming out of the coil or at the plugs. if spark is weak at the plugs it could be a bad cap/rotor, ignition wires. it could also be an ignition module problem or pick-up coil in the distributor.
Swap the coil with one of the other coils. If you still have weak spark out of that tower than replace the coil.
If you have strong spark once swapped and the other coil tower now has w eak spark replace the module.
Fresh Fuel Clean carburetor if stored with fuel in the tank and wasn't shut off Clean fuel filter Clean air filter Proper oil level Clean spark plug (just replace it, it is easier and faster)
Hello . If you have a weak spark it could be the ignition coil that needs adjustment or a bad ignition coil . To find the ignition coil simply follow the spark plug wire . To readjust the coil get a piece of paper , loose the bolts on the coil and put the paper between the coil and the flywheel (higher part of the flywheel or magneto) tight the bolts and remove the paper .
Check for spark . If still a weak spark just replace the ignition coil .
Hope this help.
