Nikon D60 Digital Camera Logo
Posted on Mar 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AUTO FOCUS NOT WORKING. SOMETIMES IF YOU REINSERT BATTERIES THE FEATURE WORKS AGAIN
pictureman4u
Level 2:
  • Expert 132 Answers
  • Posted on Mar 26, 2010
pictureman4u
Expert
Level 2:
Answers
132
Questions
0
Helped
43932
Points
329
Auto focus for an for digital cameras have a nasty habit of that, do what I do, and my Auto Focus works too, but I use Manuel focus all the time, and I shoot professional golf....I never auto focus nothing....my eye is faster and better than the lens.
2answers
Canon 10x30 IS binoculars problem
It sounds like the image stabilization feature on your Canon 10x30 IS binoculars is not working properly. Here are some steps you can take to troubleshoot the issue:
  1. Make sure the batteries are properly inserted and charged. The image stabilization feature requires power from the batteries to work.
  2. Try resetting the binoculars by removing the batteries for a few minutes, then reinserting them.
  3. Make sure the binoculars are being held steady and that you are not moving too quickly or shaking excessively. Image stabilization works best when there is only slight movement or vibration.
  4. Check that the image stabilization switch is turned on. The switch is located on the top of the binoculars near the focus knob.
  5. If none of these steps work, it is possible that the image stabilization mechanism itself is faulty and needs to be repaired or replaced. Contact Canon customer support or a professional camera repair technician for assistance.
It's worth noting that image stabilization is not a perfect solution and may not completely eliminate all movement or shaking in your images. It is designed to reduce the effects of minor movements and vibrations, but cannot compensate for large or rapid movements.
2answers
Error code 99 eos 400d? Camera won't work
Err 99 Some other fault.
There is something wrong, but the camera does not know what.
This number is for all errors the camera can't handle.
Try the normal "reset" method as follows:
Like a cold boot for a computer, the camera can be "rebooted"
follow the following steps:
Switch of the camera and remove the battery.
Remove the memory card and the lens. (if possible)
Recharge the battery. Wait till the indicator on the charger indicates the battery is fully charged.
Check all contacts, if they are clean and shiny. Contacts (from battery and memory card, only to be cleaned with a dry cloth or cotton swab(s).
Reinsert the battery, reinsert the memory card and re-attach the lens.
Then switch on the camera.
If this does not help, contact a certified Canon repair centre.
2answers
Blurry pictures even through the viewfinder window. I've changed settings and nothing seems to work.
maybe its on manual focus. take the batteries out and reinsert them
put it on the green auto program. If that still doenst help the auto focus is damaged
You can also bring it to a photo dealer and ask them how much it is woth if you trade it in. The will discover the issue and tell whats wrong
for free :) as long as you dont let yourself lure of course
good luck
rene
1helpful
It seems to be focusing, but the pictures are blurry - lens is clean, same issue when auto focusing or manual focusing. Doesn't seem to make a difference if I hold the shutter down only halfway to give it...
Please make sure that you're using fully charged battery pack.
Remove the battery and reinsert after 1 minute.
Reset the camera by following the reset procedure from the manual of the Camera.
If the issue persists again, service is required
1helpful
Lens will not auto focus any more.
Hi there!
I experienced the exact same problem with my 100-300mm lens and I was never able to get it to work correctly again. In fact, attempting to use it further seemed to exacerbate the problem.
The further you zoom, the wider the aperture opens allowing more light for the camera to focus properly. If the aperture mechanism is damaged, the auto-focus process may not work as it should; which would explain why the auto-focus feature works only when at 18mm.
Regardless, I strongly recommend you discontinue use of the lens until a professional technician can examine the lens and figure out what's going on. I'm sure you can contact the manufacturer to open a support case or you can find a camera store that offers repair services.
I hope this helps!
1helpful
2answers
Close up shots won't auto focus.the lens trys to adjust but the final setting is out of focus. the camera works fine on subjects at least 2 feet away
try using the little throttle that is located just below your on/off switch. if you push that either up/down, it should help you manually focus your subject. It is actually a really fun feature to play around with.
2answers
Nikon D80
Hi taylorrm, I don't know if you have a solution to this but sometimes the AE-L/AF-L but gets pushed which is the auto focus lock button then the shutter release button cannot be used to focus and yu have to reset by pressing it again.  Even though it's confusing at first it's a feature along with the AE/AF Lock to try out to lock your focal area on a subject prior to shooting.
To sbhoward5, check to make sure the switch on the camera body is switched to AF instead of M mode(looking at the front it's on the lower right hand side below the lens release button), which sometimes happens when changing the lens - so then the mode selected is in P,S,A, or M modes on the mode dial. happy shooting,
randy320sgi
Nikon D70 SLR Auto Focus
problem in lens censer replace it
15helpful
3answers
D80 lcd flashing "F- -"
ive had this problem before, on my camera it means that the lens isnt rotated all the way onto its engaging point on the lens mount... it gets a little loose and shifts out of the way sometimes...
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
