Washer is "stuck" in mid-cycle and will not drain and spin. Makes a grinding noise. After a few minutes, all lights around cycle choices flash. Drain water has had a bad odor for the previous month.
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Kenmore he2 nothing happens cycle light just flash and add garment is s lite up
My kenmore elite washer won't start. all display lights work.
