Question about Canon Pixma iP2600 Photo InkJet Printer
Spooling printer output, but no actual output?
I'm running OSX 10.6.2 on a brand new i-mac.
i was able to set-up an ECRM stringray printer/rip and print to it successfully for about a week. a few days ago, i "canceled" a print job as it was coming over to the rip through the ECRM RipMate software.
now, when i try and print to the ECRM rip from my mac, my print dialogue will show the job spooling LPR to 100%, then nothing happens.
the job leaves the print queue and there is no output, this happens quickly.
i did delete the printer and recreate/reconnect it but i still get the same result, spooling LPR to 100%, then nothing...
i do have two other older macs that have no problems printing to my ECRM stingray/rip.
6ya staff
SOURCE:
Anonymous
SOURCE: I cannot get my printer
have you gone to add printer on your computer and picked the 620.
Posted on Jan 14, 2009
Fabio
  • 400 Answers
SOURCE: MX 310 Not seen in Mac printer list, so cannot install
The drivers are here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603
Did you connect the printer via the USB cable when prompted?
Also check the instruction manual to make sure it was setup correctly.
Posted on Jul 03, 2009
mdgm
  • 89 Answers
SOURCE: I can ping, but I can't print
Sounds like firmware is not correctly installed. Did you try installing a network kit yourself? You need to get a tech to upgrade firmware using SST. This should install onto the copier the RUI and PS/PCL so you can print.
Posted on Jul 17, 2009
mdgm
  • 89 Answers
SOURCE: Printer keeps pausing itself!!
dev_24ind: The parallel port cannot be used for printing by default. Heaps of people have made this mistake. You need a N Boot Rom installed and N system software. Almost certainly you don't.
Get a Network Multi PDL Printer Kit C1 for IR3300 (contains N Boot Rom and NIC aka ethernet port). A technician can install this and update system software and you will be able to print. You will be able to print over a network (which is the preffered option) use Remote User Interface and Pull Scan using Canon Network ScanGear (google it).
Posted on Jul 18, 2009
muntejaya
Muntejaya Ginting
  • 10421 Answers
SOURCE: I'm using Mac OSX 10.5.8. When I try to print, the
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay npbct
Posted on Feb 12, 2011
Canon MG6460 won't print on Mac
new too mac osx software having trouble setting up my canon pixma mg6460 software? any help much appreciated
Nov 24, 2013 | Canon Office Equipment & Supplies
Samsung CLX-3180 Series calibration
If it's virtually brand new, why can you not invoke the warranty to demand a replacement?
Jun 09, 2012 | Samsung Office Equipment & Supplies
My Mac OSX (version 10.6.6) (processor-2.4 GHz Intel Core 2 Duo) will not print on the dell V305 and this has been going on since I got the computer around the date 1/11/11!
I had this exact same problem. These Dell printers are really Lexmark with Dell branding. They will simply not work with Mac OSX. The only solution I came up with is to make a network printer on your home network. That will work with any combination of Macs and PCs.
Feb 25, 2011 | Dell V305w All-In-One R840635AU InkJet...
My Mac Book Pro is showing an error when I print
Throw away your HP disk and delete all HP software installed on your machine. It's quite rubbish.
Go to system preferences, and printers. Remove your HP printer (by selecting it and clicking on the '-' Then click on the '+' and let OSX find your printer and automatically load the driver. Now it will work.
Jul 16, 2010 | Apple MacBook Mac Notebook
User Auth. for Mac on BizHub C250
setting up auth. on mac requires that you open the doc on appropriate app, on print menu select output method, set auth. credentials, and save. then print. some mac OSX ver. will save others won't. prompting you to set auth, every time you need printing.
Aug 26, 2017 | Konica Minolta bizhub C250 All-In-One...
Had a new hard drive installed and need to re-install Canon Pixma Mx 310 all in one back in my Mac
Dec 16, 2008 | Canon PIXMA MX310 All-In-One Printer
Printing to a Xerox DC12/DCS50
you can't print via serial to it. You will have to check the settings in your rip to see what the ip address is. Lights will blink all the time to indicate it is on a network, its just not talking to it. Then you go into your add printers section click the + sign and it should come up in there if the ip address is in line with your mac ip
Dec 16, 2008 | Xerox DocuColor 12 Printer
Mac and hp 7780
I had the exact same problem but never could get my Mac to work wirelessly with my 7780 even though the box said it was wireless and worked with OSX....false advertising.  Enough of the problem though.
I set up my printer through my Airport Extreme network.  That solution worked sporadically.  I would get error messages that the computer could not open the printer.  I found clicking the "pause" print button and then clicking "resume" would often work but needless to say that became a pain.
So, my IT guy set the printer up through it's IP address over my airport extreme network.  The printed has worked flawlessly for the last week since this change but.....the fax no longer works and now the scanner takes about 3 minutes per page.
Overall, I have been a die hard HP fan for years but after the nightmares with the L7780, I will NEVER use another HP product.  The item cost me about $459 but I have lost or spent over $5,000 in diminished productivity and IT charges and it STILL DOESN'T WORK AS ADVERTISED!
Jul 10, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Can't print to a shared HP Laser Jet 2015 printer (Mac)
On the two non working computers...uninstall the printer drivers and uninstall any info about the printer reboot.reset up each indivual (the two non working ones)computer with new drivers from web.reboot and they should work.RICHARDM69
May 02, 2008 | HP LaserJet P2015dn Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
110 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
