I have an iphone and earlier today i actaully tryed chraGinG it the battery & red lighting bolt came up but after that the phone went blank & wont turn on or charge
Check your charger in a different iPhone, or the sync cable also. Check to see if your dock connector isn't tarnished, if it is clean it with a CLEAN DRY used toothbrush. Has your phone been wet?
These are all the typical culprits when a phone will not charge. I hope it isn't the wet problem! Good luck!
Un plug the battery check the connections on the battery and the iphone clean with some stochbrite and wipe off with 90% alcohol let dry and should work fine as long as the battery is fully charged.
Hello !
I was in panic attack !!! did everthing and nothing seems to wake up my iphone.
I forgot to charge it so battery went full empty, then I plug it on the wall charger, and nothing happend. I let it all nite, and next morning,... surprise !!!!! still the red icon, No battery, the iphone didnt restart!!!!
How I fix it?
1-unplug it from the wall charger
2- press middle button and startup button, same time
3-when red battery dissapear, plug the charger.
4_ do this many times. Didnt work for me the first time, but at the end it works !!!!
NOW MY IPHONE IS WORKING GREAT !!!!!
GOD BLESS YOU ALL !!!!!!!!
Your battery is gone, you will need to replace a new battery because the old battery is at it age. When you get a new battery, charge it 24 hour to fully charge it before you use, it is very crucial to maintaince the life of battery
