My Panasonic Viera 42 in. flat panel tv was accidentally knocked over. The screen looks okay and the sound is fine. The picture looks like a broken black mirror. Is the tv worth fixing or should I just dump it. (It is only 1 month old).
Sounds like a panel fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Screen-shots to defective LCD TV panel is given. You can compare it to that of your TV's, and can make sure.
Does it display channel numbers or other pictures when you press menu or other tools? If so, it's a problem with the TV's video inputs. If not, it's something wrong with the projection hardware, matrix, or power supply. Failing that, I recommend contacting Panasonic's support center, and keep any information you have on buying the TV handy. Good luck!
make sure your speaker to your sheron sound isnt to close to it .also if dvd player is the source then move away from tv will demagnatize the tv theres a magnet in them
It's called Cyan and it's sound like you are having a problem on your D-board. Look for capacitors bulging out and replace first if not then order D-board
The screen is cracked internally, there are glass layers under the top plastic film. You could get the screen replaced but might be as cheap to buy a new TV.
