SOURCE: need belt schematic for 2006 toyota corolla
I can get you a diagram on monday but it goes from the alternator to the power steering pump then around the tensioner pulley then around the crank pulley then to the a/c compressor then pull on the tensioner to give you some slack and slip it on the waterpump.I hope that helps.Let me know if you still need the diagram
SOURCE: need diagram for a serpentine belt of 2006 toyota corolla 1.8 wit
Is the diagram on a sticker, on the underside of the hood?
SOURCE: need serpentine belt diagram fo r2001 toyota
if the pulley is smoth the belts back rides on that surface if it is ribbed or lined the inside of the belt rides on that surface , you local parts store should have a diagram or dealership .
SOURCE: Replaciing serpentine belt on 2006 Toyota Corolla
You'll have to remove the engine cover under the bottom so you can position the new belt on the pulleys properly. Get a wrench or tensioner tool and turn the tensioner clockwise to relax the drive belt. Don't apply excessive force.
It's hard to draw a picture with words, but looking at the engine from the passenger side of the car, there are basically two top pulleys, two middle, and two bottom. The drive belt goes around the outside of the two top and two bottom, and on the inside of the two middle.
