MY WASHER STARTED NOT DRAINING COMPLETELY, ON THE NEXT WASH IT STAYED IN CYCLE, WATER CAME IN AND IT SOUNDED LIKE IT WAS WASHING BUT THE DRUM DID NOT TURN. I TRIED IT IN SPIN AND AFTER A FEW MINUTES IT TURNED 3 TIMES THEN NOTHING. IT IS STILL JUST SITTING IN THE SPIN CYCLE. ANY IDEAS?
Hiya
the filters are usually located behind the plastic kick plate on the front of the machine or behind a flap also on the front of the machine.
if the filters are all clean then it maybe that the motor brushes are worn down and so the machine wont spin
it could possibly be a faulty pressure switch not telling the machine that the water has completely gone and again wont spin.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Where are the filters??
Pull off the front panel and emty your filter to the pump
Try cleaning out the filters
I cleaned my filter - and it needed it - but it will not spin - goes through all the other cycles but does not spin - any help would be appreciated.
Whirlpool front loadeer - DUET
It must stop and start 50 times while trying to complete a cycle, which it does after a few hours
