Question about Kyocera RI-3530 Black and White Copier
Morning, my copier machine is the type of kyocera mita km-1650 then if i switch on it gives me error of call service c6000,Please can you help me?
    New Friend:
  • 74 Answers
1650 machine is a medium size machine for small offices and home users. The machine is equipped with a self diagnostic function so it displays an error code whenever its processor detects a problem during copy process.
Some codes can be reset by simply opening and closing the front door or by turning the machin on and off, but there are some others that can be reset only by a service representative. C 6000 code is one of them. There are several causes that lead to this problem, i;e:
1. Unstable power source
2. Low volatage
3. Broken thermisted wire
4. Poor contact in the thermister connector terminals.
5. Heater lamps are broken or not installed correctly.
Here is the process to reset c 6000.
Enter 1087-1087 (1087 twice) from the keypad.
U000 will be displayed.
Enter 163 by using the keypad keys.
Press "Start" (the green button) twice.
The code will be reset and machine will start automatically.
If this code is appeared again, you may need to check the fusing section of the machine and it shoud be done only by a service engineer.
Posted on Mar 27, 2010
Anonymous
SOURCE:
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
www.youtube.com/watch?v=Ef0WwaTXgtQ
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
pritner.blogspot.com/2013/08/solving-error-c6000-on-kyocera-mita.html
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 · Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
Oct 19, 2015 | Xerox Phaser Office Equipment & Supplies
How to remove error code c6000 from km-1650
reset fuser error in service mode ,simulation 163,
Jun 03, 2014 | Kyocera Mita Office Equipment & Supplies
Kyocera mita 5035 eror code c6000
i have kyocera mita this machine toch screen is working but numbers manual is not working please give me solution immediately
May 26, 2012 | Kyocera Mita KM-5035 Printer
Morning,
A C6000 is as follows:
Broken fixing heater wire In fixing warm-up, the time to reach
50°C/122°F exceeds 13.5 s, the time to reach 100°C/212°F exceeds 10 s, the time to reach the primary stabilization
exceeds 10 s or the time to reach the secondary stabilization exceeds 24 s.
Solution:
Fixing heater M or S installed incorrectly.
Check and reinstall if necessary.
Broken fixing heater M or S wire.
Check for continuity. If none, replace the fixing heater M or S
The heating M or S are the hologen lamps inside the unit.
You can try to reset the fuser by entering the following
10871087 this will put you in maint mode.
163 then press start and you may have to press start again. If start doesn't work then you have to press ok.
then unplug unit and wait 30 secs. and turn back on.
Hope this helps.
May 14, 2010 | Kyocera RI-3530 Black and White Copier
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera RI-3530 Black and White Copier Logo
276 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
