Refrigerators Logo
Posted on Mar 24, 2010
Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
My ice dispenser stopped working. The Ice maker works but will not dispense ice.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Mar 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
2034
Points
9
Try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Ice dispenser grill
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
No water from dispenser but ice maker working
You have two sides to the water control valve and it is most likely the dispenser side of your WR57X10051 Dual Water Inlet Valve I will be here should you have more questions, Thanks Sea Breeze
Ice dispenser
THere is a plastic "hub" at the back of the bucket which attaches to the auger. THE "hub" catches a "fork" like device at back of ice maker which turns. The "fork" turns and in turn is supposed to turn the auger. That plastic hub could be torn up, broken, jammed, or otherwise not working correctly. That is what is wrong with mine.
GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
The ice maker stopped working on our GE Profile refrigerator.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
;jlhk
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Ice dispenser not working
your welcome sorry i wasnt able to save you a service call
Top Refrigerators Experts
vince
Johnny 1000
