I assume this is your wireless KEY
The user manual is here
http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_GBR&knowsPartNumber=false&productCategory=1&modelNumber=955&partNumber=3552&downloadType=8&os=0
you can choose the exact model from here
http://www.smc.com/index.cfm?event=downloads.searchCriteria&localeCode=EN_GBR&knowsPartNumber=false&productCategory=1&downloadType=0&os=0
You should be able to see how to view or reset the wireless password.
Connect your PC to the Router with a LAN cable:-
You will need to login to your router- you do this by typing a number into a web browser, Internet explorer, is best as some routers do not work with other browsers
The way to log into the router is usually to use the IP address, thats a number which will be in the manual - Page 29 on the manual (33 on pdf screen)
To access the Wireless Barricade’s management interface, enter the Wireless Barricade IP address in your Web browser http://192.168.2.1. Then click LOGIN. (By default, there is no
password.)
Goto the wireless section - secruity and you should be able to see the KEY - IF its all * - the you can type in a newone
I would also remove the wireless profile from your PC - to do this have a read of this link.
Remove the wireless profiles from your PC http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
