Question about Samsung LE32R72BX 32 in. HD-Ready LCD TV
LE32R72BX/XEU Samsung 32Inch is coming up with nothing but interference no matter what input is put through it and it flashes up intermittently with a blank screen every 2 seconds or so I can get no menus or change anything about it does anyone know what is going on?
    Genius:
  • Samsung Master
  • 1,039 Answers
Check power board for domed capacitors and replace them. Next if needed replace the main board.
Posted on Mar 26, 2010
6ya staff
SOURCE:
My Bose Cinemate series ii is making very loud intermittent crackling sounds
Usually made from interference of some sort. Make sure that all wire connecting from both the input on the receiver and the output devices are properly secured and have no rips or tears in them. Also make sure there is nothing close the receivers with a powerful magnet (big subwoofers, powerful speakers, computers, etc) those can also cause interference. Hopefully this helps.
Sep 25, 2012 | Bose 318842-1100 - Cinemate Series Ii...
We have a Samsung Fridge Model No: SL39WJ1/XEU - the door is alarmed but now the alarm keeps just going off - for 3 days now and now going off every few seconds. The temperature lights etc at top of...
Even though this video shows a different refrigerator model, I have seen this with Samsung refrigerators (mine for example). I hope this helps.
Nov 22, 2017 | Samsung Refrigerators
My new Samsung UN65C8000 LED TV has an intermittent pattern of horizontal banding that is present probably 70% of the time and varies from narrow width banding to wider width at times. This is the second...
You did not say if the first one went back for the same fault. If it went back for a different fault then this set is faulty! If not then unless it it more susceptible to RF interference possibly mains borne than the flawless set (that is possible) and you have some other equipment in the house which is radiating like a power supply or dimmer or whatever, it must be faulty. Turn everything in the house off just to be sure nothing is causing interference. Even then it could be picking up interference from elsewhere. What affects it or does it seem random (position time of day etc.)? The only way to be truly sure is to try it in another location
If it's new why not return it?
Feb 16, 2011 | Samsung UN65C8000 TV
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
I have a samsung tv and dvd player and it has just started coming up on screen when i load a dvd to play a region error messagesayinh no good.It has been working ok before this.i just recently upgraded my...
make sure your tv is set in right language and location because after the big re-tune you might of entered wrong ones
the best way to do this is reset back to plug & play put tv in analog mode press TV/DTV on remote and then MENU ( NOT DTV MENU ) move down until you see plug & play in one of the menues press enter and follow on screen instructions
Pilot light on samsung SP 54T8HE projector jst flickers
Hi
are you a technician for this unit? if you are i can help you to fix this...
Thanks!
Jan 15, 2009 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
Samsung rear projection sp42w4hpx/xeu
Try plugging the power cable out for the night. If it doesn't solve it there's probably a problem with the power supply that needs professional care. Good luck
Jun 05, 2006 | Samsung HCN4226W 42" Rear Projection...
Samsung LE32R72BX 32 in. HD-Ready LCD TV Logo
184 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
