Samsung LA32R81B lcd tv is lock in channels only. I need the code to unlock the tv itself. Pls advised.
SOURCE: Samsung lcd faults
Found this on FixYa and it worked:
I had a similar problem and the way to solve this is to reset the set from the remote. Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Peter
SOURCE: Samsung 32'' LCD (LA32R81B) is as good as dead
I would venture to say it is the power supply first. Capacitors in LCD power supply's frequently go bad after a year or two. LCD displays very seldom go bad and I have not seen one kill a set completely.
SOURCE: I need free unlocking codes for samsung E590
hai, I agree with venkat. But i also found the site called http://www.mobile-unlocker.com/.It's also having the code and instruction for samsung mobile.
