Water is leaking from front door gasket when washing cloths.
Before you go to the expense of replacing the door gasket, try cleaning the glass door itself with a soft plastic scratcher. Scum builds up on the glass and does not allow a tight seal. Be careful not to use a metal scratcher as it might scratch you glass door. If this does'nt work then ispect your gasket for tears or holes in the gasket, and inspect your door hinges to make sure they have not been bent. Good Luck, Appliance Specialists
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution.It is possible that water can leak if there is gaps on the front door gaskets and must be checked for damaged gaskets which can give poor sealing of the door. So in this case the leak will happen more during the cycle and not on the drain cycle end.
check this video to see how to replace the door gaskets.
