I simplified the "getting rid of predictive text" instructions for people with the cheap STRAIGHT TALK LG phones! a)Push the message button directly above the SEND button. b)You\'re at the message screen to type in. c)click on "options," lower left of your message screen. d)click "text entry mode." e)then choose "abc," click on "set" which appears on that screen. You\'re done. You can now dang well type what you want. That\'s how people in the "factory default setting" department get their jollies!
SOURCE: Predictive Text
Go to Menu>Messaging>New Message
Then go into Options & scroll down to Text Entry Settings and there should be an option that says T9 Word Prediction, go into that and change it to ON
should be good to go
SOURCE: texting without using predictive text
Predictive text (or T9) is usually turned off by holding * or # for few seconds, or you may need to go to message settings and turn it off there. What kind of phone are you using?
SOURCE: how to turn off predictive texting on Motorola i425
go into a text message and push the button right above the green send button and choose alpha....problem solved
SOURCE: Predictive Texting on Sony Ericsson T303
Took me a while to work out. Hold down the hash key (bottom right on the keypad) when in the text window and select English from the languages that come up.
SOURCE: i580 Predictive Text!!!!????
Go to Messages,then go to Create SMS the message multiline appears . Now press the round button in the centre of directional keys, this will take you to message editor. Now go to Entry set up . In the Primary setup select TAP english and in the secondary set up select TAP English.
I understand that u r unable to write message according to ur wish, Ur t9 dictionary is activated so pliz turn it off definitely u will b able to type proper text.
