Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
Anonymous Posted on Mar 25, 2010
Sony wega kdf42we655 power led blinking red
Will not start up. when power button pushed hear "fan" type sound briefly then nothing.
  • Anonymous Mar 26, 2010
    Thanks, I had just replaced the bulb. Turned out that I hadn't pushed the lamp cover in securely enough. Took it out, put back in until I heard a click, then screwed in place. Worked perfectly. (Also- turns out the solution was right there in the owners manual after all!)
  • Myra
    Myra Apr 30, 2016
    I don't have an owners manual ...thank you very much
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Mar 25, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957026
Points
33084
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
    Thats great tv is working fine now.
  • Myra
    Myra Apr 30, 2016
    It blinks 9 times
2answers
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Sony HD Projection TV KDP-57WS550, timer light blinks 5 times and repeats sequence. When power button is pushed sound comes on briefly, no picture, then TV goes off. Please advise.
Mine did this after a power flash. Lights blinking 5 or 6. They blink fast lol. I have sound till tv powers back down. Front yard bond fire? Or any ideas? Thx.
2answers
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
2helpful
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Sony wega kdf42we655 won't turn on...green light blinks, faint whirring sound, (fan?),then nothing...red blinking
Did you notice if the screen has been recently going darker if so the lamp has gone.You can check it by removing the lamp and looking at it you will see a grey smoked area or even the lamp mount broken inside the lamp.
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
5helpful
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
1helpful
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
standby button blinks no picture no sound have tried to reset and restart nothing has worked to get tv to back on
1helpful
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
