The power was on, red light, swithched to on, blue light, opened the disk tray, inserted a disk and closed the tray. At this point the blue light went out and now the red light flashes and I cannot get it to stay solid or turn blue.
I had already tried this, unfortunatley it didn't work. Thanks for the idea anyway.I had already tried this, unfortunatley it didn't work. Thanks for the idea anyway.
You can't post conmments that contain an email address.
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
There is no tray on the playstation 3. It's slot-loaded drive; meaning it pulls the disks in and spits them out without opening a tray like you see on a desktop PC or a Xbox. If it's just beeping then that usually means there's no disk in there. The best way to check is if you see a blue light beside your red/green power light, then there's a disk in there. If it's just your red/green power light, there's no disk inside.
Try slowly opening it with a flathead screwdriver. Get the tray open enough to put ur pinky in and try to remove any disk(s) that are in there. Plug it in and turn it on. If the tray closes ur system should be ok and try to open it with the button. If no good. Then try agian, but this time slowly open it all or most the way, then plug it in and let the drawer close and see if the button works to open and close it.
This is ussaly caused by a jam from either a incorrectly inserted disk and it jammed the tray. Or the gearing that is connected to the motors jamed up and the tray needed to be moved out to unlock the jam.
Closing the tray with ur hand and not pressing the button to close it also could of caused this problem
check the micro switches on the cd mechanism. these can go wrong sometimes. it's obviously not sending a message to the micro chip that the tray is open therefor it will close again automatically.
There should be a small hole on the door of the disk tray. insert a paper clip in the hole to manually open the disk tray. remove the disk and see if the tray will open and close normally. If it does put another disk in and see if all is well. If not I would have a repair center look at it.
you say it wont turn back on but it has power. is the light red ( stand by ) or do you have green and blue lights Did it fall???? try cleaning the disk and the lens you can also run the auto diagnosis..
HERE'S HOW Auto-Diagnosis (PlayStation 2 system)1. Turn on the system without a disc inside.2. Once at the Main Menu, press the triangle button to enter the Version Information Screen.3. Highlight the "Console" option, and then press the triangle button again.4. Next, press the X button, highlight "On", and then press the X button once more.5. Now press the circle button twice to return to the Main Menu.6. Press the eject button on the front of the console, and insert a disc.7. Now close the disc tray, but DO NOT reset the system.8. Highlight the Browser option from the Main Menu, and then press the X button.9.
In the Browser, an icon of the disc should appear on the screen.
Highlight this icon, and then press the X button to read the disc.10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
have you got it set on an IDE cable on it's own and if so have the jumper at the back set to master the other thing to do is power of pc and remove ide cable from all devices and leave power cable to burner then torn on pc if you have removed power and ide cable from hard drive then when pc boots in press button on cd,dvd drive to open tray then place cd lense disk or any cd in drive tray press close button and let device kick in if it picks up disk then try with a dvd disk with power on pc if all goes well try with a ifferent Ide cable to motherboard and reconnect harddrive and power up if all goes well the pc should recagonise it if not then get it replaced
try holding the disk drive after it closes for a few seconds and see if it stays closed or one of the drives gears could be stuck,loose,or broken.you might need to open it up.
This has happened to me before. You will have to open the PS2 and clean the laser which is under the tray(or on top i forgot).
Use a cotton bud to clean it but be extreamaly careful cause if you put to much pressure on the laser your PS2 is gone for good!
