Question about Sunfire True Sub MK II Subwoofer
Sunfire MK II Hums on input signal. Hum can be canceled repeatedly by switching on or off lights in room. Problem is consistent. Sometimes a small electric shock can be felt at a light switch. Is this a grounding problem? How important is a proper ground?
  • 682 Answers
You must change light switch now with a new one-and grounding is very very important.
Posted on Mar 25, 2008
6ya staff
SOURCE:
How to get rid of hum in output of my Akai 4000ds Mark II reel to reel tape recorder
I can't see this question answered anywhere. There is information for fixing hums on bother the Mk I and Mk II models of the Akai 4000DS here:
http://electronicaid.webs.com/
Oct 25, 2011 | Quantegy 456 Reel-To-Reel Recording Tape
Having a low level hum after it starts to be used, then shuts off after a small amount of time, between 5 and 30 minutes.
use a ground loop isolator from radio shack, the device is hooked up to the rca plugs in, the other side has, (of course rca plugs), outs. solved My problem of feedback in the sub and into the processor.....
Feb 09, 2011 | Sunfire True Sub MK II Subwoofer
Sunfire MK II Subwoofer hum. I have a Sunfire MK II subwoofer that hums when it is plugged in (it even hums when no signal is connected). I've tried multiple outlets on different circuits, but hum...
you have a ground loop issue you could purchase a ground loop isolator, jensen makes them for about 40 bucks.I have discovered that if you have cable tv, unplug the incoming cable in your cable box and see if hum disappears.
Nov 25, 2010 | Sunfire True Sub MK II Subwoofer
My sunfire subwoofer starts making humm noise after a couple minutes while listening music,,, I have to disconnect and connect back, is something that involves equipmenrt adjustment?....thanks
Try plugging the unit into a clean power supply without anything else on it. I had this problem for years and eventually resolved it by moving the system to a different room that has three power circuits - the sub is now on it's own circuit and I don't have the problem anymore.
Nov 12, 2009 | Sunfire True Sub MK II Subwoofer
Sub doesnt do anything while plugged in ( Sunfire mk II)
Some subwoofers can sense the signal on their input and will only start when there's enough signal for long enough time for them to turn on the amp.
Try seting the "subwoofer signal out" on your reciever a bit higher, see if it does the trick, if not, try it with some other source (e.g. an mp3 or CD/DVD player) plugged directly into the subwoofer. If it still doesn't work, there's some other problem with your sub (bad connection inside sub, sub amplifier problems, maybe there's another fuse for the speaker itself, try to check it out).
If it works well with an alternate signal source, the problem might be either in reciever or the signal cable that you use, but could also be something else.
good luck
3rq8 (Triarcuate)
Jul 15, 2009 | Sunfire True Sub MK II Subwoofer
60 HZ hum
Rita's Vintage Audio Repair is a Bob Carver Company & can repairs & updates Subs at a reasonable cost try calling them.
May 05, 2009 | Sunfire True Sub MK II Subwoofer
Constant hum when the computers are connected
Hums come from several sources. A light dimmer switch on the wall. Speakers too close to a monitor or other electrical device. Try turning off everything in the room or nearby rooms, one at a time while the hum is audible.
Apr 15, 2009 | Bose Companion II Computer Speakers
Sunfire Subwoofer 110 Noise on input plugin
A few more questions-
Does the sub hum without anything plugged into it except for power? If it makes a real loud hum almost a squeal then I think the rca cable between the receiver and the sub is dead shorted and needs to be replaced. If it's more of a low level hum, then it's a ground hum caused by many things, ie........the receiver and the sub being on different power circuits in the house.......sometimes diconnecting the cable tv feed as it enters the room while the sub is connected and humming to see if it stops........the easy fix sometimes is using a 3 to 2 prong ac adapter but lifting the ground on such a powerful amp could be a fire hazard.
Sep 25, 2008 | Sunfire True Sub MK II Subwoofer
Sunfire True Sub MK II Subwoofer Logo
714 people viewed this question
Top Sunfire Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
