With a load of clothes, washer recently stopped completing the cycle once it hits the rinse and spin cycles. Turn it off and on or reset the cycle at the rinse/spin point and it may rinse but not spin or spin but not rinse. Will discharge water out the drain w/ no problem. With no clothes in it, it works fine. Pump spins freely, diverter valve is clear and looks good. No other lines blocked.
Sounds like unit is activating out of balance lever thats y it works with no load in it .possible faulty suspension rods making bowl move too much.out of balance lever is at back of inside bowl to the right. try adjusting back feet to make them about half an inch higher than the front feet .that will move the bowl away from lever giving more tolerence. see how u go please reply 4 more help
